Author Topic: CRT Emudriver - Non emulated compatible games  (Read 163268 times)
tisurame
  • Last login:July 16, 2025, 02:10:32 pm
Re: CRT Emudriver - Non emulated compatible games
« Reply #320 on: December 29, 2024, 07:02:23 am »
UFO 50
Steam
Native resolution is 384x216
It works perfectly right from the start. No need to change any configuration inside the game.
Highly recommended, since it's 50 (very good) games.
« Last Edit: December 29, 2024, 07:04:22 am by tisurame »
tisurame
« Reply #321 on: January 03, 2025, 08:30:36 am »
Void Stranger
Steam
Native resolution is 224x144, but it's too low for the monitor, so I'm using 288x192. You need to set to windowed mode 1x.
Aspect ratio looks perfect on a 4:3 screen. No need to use the 16:9 mode of your monitor.
8bitGeneration
  • Last login:Yesterday at 09:47:42 pm
« Reply #322 on: May 16, 2025, 03:04:18 am »
The Takeover and DOUBLE DRAGON GAIDEN RISE OF THE DRAGONS resolution anyone?
Recapnation
    • Eiusdemmodi
« Reply #323 on: May 16, 2025, 07:56:56 am »
Seems to be 1600 * 900 for Takeover:
DDG's design resolution is 384 * 216:
8bitGeneration
« Reply #324 on: May 17, 2025, 11:30:13 am »
Will try these, much love. Thanks!
« Last Edit: May 17, 2025, 11:32:01 am by 8bitGeneration »
BuckoA51
  • Last login:July 08, 2025, 12:59:15 pm
« Reply #325 on: May 22, 2025, 08:19:39 am »
You can't just copy my script Verbatim.
You need to change the path to the exe file yourself..
Mine is located in
C:\Games\KAGE Shadow of the Ninja\KAGE Shadow of the Ninja.exe
Yes I know, I changed the path, doesn't work (as described).
Rion
  • Last login:July 17, 2025, 08:50:29 am
  • 240p, 480i
« Reply #326 on: June 04, 2025, 10:17:14 am »
Mine is located in
What is you path then?
8bitGeneration
« Reply #327 on: June 09, 2025, 05:44:32 pm »
NINJA GAIDEN: Ragebound Demo anyone?
phasermaniac
« Reply #328 on: June 10, 2025, 09:39:41 am »
I would bet 480x270
CRTFTW
  • Last login:Yesterday at 02:35:34 pm
« Reply #329 on: July 07, 2025, 01:16:19 pm »
You can easily find out for yourself.
On a standard monitor:
In the game options, set it to the x1 window mode, where 1 pixel on your monitor is 1 pixel in game.
Run and inject Special K, open the OSD, read the window resolution.
That is the resolution of the game. Make that as a custom resolution
BuckoA51
« Reply #330 on: July 08, 2025, 12:31:29 pm »
Btw SkyRacket is listed as 384x216 but I just downloaded the demo and it's 480x270.
tisurame
« Reply #331 on: July 10, 2025, 10:46:24 pm »
Zexion
Steam
Native resolution is 320x224. It works perfectly.
Awesome metroid-like game.
