Author Topic: Pi3 plus vga666 outputting 640x480 31k help  (Read 3588 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: March 23, 2019, 09:35:24 pm »
Hey guys
I'm running emulation station/retroarch and I'm trying to output through the gert vga666 in 640x480 in 31khz to an arcade monitor and I was just wondering which values would be required? I'll post my config shortly, but any help would be greatly appreciated  :cheers:
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
MAME TIME
Re: Pi3 plus gert vga666 outputting 640x480 31k help
« Reply #1 on: March 23, 2019, 09:53:02 pm »
BTW disable SPI and IC2
heres my config
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#config_hdmi_boost=6
#hdmi_ignore_edid=0xa5000080
#hdmi_group=2
#hdmi_mode=4
#this was added to force vga note 640x480 60hz
dtoverlay=vga666
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=4
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
gpu_mem_256=128
gpu_mem_512=256
gpu_mem_1024=256
overscan_scale=1
# Pretends no audio formats are supported by HDMI display, forcing all sound out the 3.5mm headphone jack.
# May not be needed for all HDMI devices
#this was turned on to enable the 3.5 audio jack
hdmi_ignore_edid_audio=1
Geometry Arcade
Neo Geo 360
MK2 standup
