Author Topic: Golden tee 2005 Boot question  (Read 2589 times)
alrolon800
  • Last login:October 10, 2019, 07:47:51 am
« on: February 23, 2019, 11:04:47 am »
Has a few problems. first monitor is out. very dim with retrace lines. I think flyback, as it started snapping a few times when first turned on. Now I think hard drive also bad. I believe machine in storage since Aug 2012. (last updated according to upper display.) I want to check Green board. If I remove hard drive should both green leds continue to blink or only the #2 with #1 solid because hard drive removed. All voltages are good. 5.2 and 12.3vdc.
