Main > Main Forum
Where to get Plexi Glass in Australia
microwrx:
Looking at their website it looks like Bunnings are based in WA so you shouldn't have a problem. The 3 local stores I have been to all have the stuff I listed earlier and they all had it in the same section as their similarly sized sheets of MDF and melamine.
Like I said, around $45 for a 900x600x3mm sheet of clear or grey(smoked).
Cheers
JJ
Stingray:
I'm not in Australia, but here's what I did. I pulled out the phone book and looked up 'plastics'. Lo and behold I found a place about two miles from where I work that sells nothing but Plexiglass. They cut the pieces I needed and it was dirt cheap.
-S
ErikRuud:
Plexiglass is usually called "Perspex" in the United Kingdom. I think the same is true in Australia as well.
cdbrown:
It's called both here in Oz. It's good to know I'm not the only one from Perth on these boards. Unfortunately I haven't checked to see where to get them from yet. I would have made my first stop at Bunnings just for convenience then moved on to a plastics manufacturer - perhaps someone like Cadillac Plastics.
exian:
Thanks for all the Replies Guys... ;D
I called Bunnings and they did not know what I was Talking about, So I am going to drop into one of the stores and check it out myself.
I'll let you all know how it goes...
Navigation
[0] Message Index
[*] Previous page
Go to full version
