Main > Driving & Racing Cabinets
I am a complete idiot (Daytona Championship related)
<< < (2/2)
MrThunderwing:
--- Quote from: clos2345 on July 10, 2018, 11:16:53 pm ---I think the beep has to do with x360ce. In the options tab, there is a check box that says "Use Init Beep". If my wheel and shifter are plugged in then I get one beep.  If I have something unplugged I get continuous beeping and the game doesn't load.
Ah, I'll look into that next time I fire the game up. I've found a new launcher and instructions on how to patch the game's EXE (again) using ppf-o-matic, which also has the added advantage of 'Gear shifts never miss' which used to happen occasionally with the old version I was using. Haven't got around to actually trying it out at the moment, we're in the middle of a heatwave in the UK at the moment and I really can't be arsed to get my wheel out and set-up when I get home from work ,because it's just too hot to think straight.
--- Quote from: ResurrectionHQ on July 11, 2018, 07:37:42 am ---if you use discord or something maybe I can contact, because writing the steps of stuff one by one will be a hassle in here. There are still more stuff to be discovered in the bunch of the game files, so... yeah.
I'll be sure to help you out.
Ah, NVM. I don't do Discord.I was hoping it was just a simple fix in the test menu or summat.
Ali:
Please, Is possible to play Daytona USA Championship New Seasson in the PC without an emulator? Is it available to download (to play without emuator)
I know it is available to Teknoparrot...
Is there a tutorial how to configure the joysticks to play it?
In my PC I apparently, I can play it Daytona USA Championship (no New Session) in very directory...
Many thanks...
Nuexzz:
--- Quote from: Ali on July 11, 2023, 03:44:49 am ---Please, Is possible to play Daytona USA Championship New Seasson in the PC without an emulator? Is it available to download (to play without emuator)
Many thanks...
at least I use daytona3 without teknoparrot.. the cleaner, the better. at least for me.
Ali:
--- Quote --- at least I use daytona3 without teknoparrot.. the cleaner, the better. at least for me.
Thank you Nuexzz!
Ok! But You can't use the updated version  Daytona USA Championship "New Session" directly in your PC, right?
Three days ago I downloaded Teknoparrot. I've always had a prejudice with things like Teknoparrot, Emulator Managers... too many layers in your system (I'm a old school Mame user)...
But as far as I could understood... The Daytona USA 3 is basically a "PC game" and what it does is basically to emulate the controls using your PC joysticks, and keyboard! Aparently no a real game emulation at least in Daytona case! Running at full speed!
Tip: Do you know the "classsical mod" for Daytona 3 Championship?
It restores the classical Daytona features (musics, sounds...) and remove the Stupid Lasers Rays(?) departuring from other cars...
The author said me, maybe he will do a mod for the New Season update...
Try to run Daytona (the 2 versions!) in Teknoparrot! I could to use it only after 10 minutes using the new Web Installer!
Nuexx, I'm a user of your tools/mods for Daytona USA++, many thanks!!
Best regards!
Navigation
[0] Message Index
[*] Previous page
Go to full version
