Main > Driving & Racing Cabinets
Chase HQ 2 finally cracked!
<< < (30/30)
Malenko:
--- Quote from: BadMouth on September 24, 2023, 08:36:30 am ---Thank you.  I lie awake at night worrying about the PMs he no doubt received.
My attempt to moderate in this sub-forum once every four years has failed.
You're not the worst mod, thats for sure
funsunsea:
I have a Chase HQ 2 cabinet with a dead HDD. Would this work in the Taito X2 plug and play?
buttersoft:
--- Quote from: funsunsea on November 24, 2023, 07:04:32 pm ---I have a Chase HQ 2 cabinet with a dead HDD. Would this work in the Taito X2 plug and play?
Maybe. My understanding of X2 and TTX was that it's a windows install running software that is decoded by an encrpytion dongle - does that sound right? If you have a dead HDD, can you not clone the working one and just replace it? (RH above means right-hand cabinet, of a side-by-side?)
If you can't do that, from memory the X2 system links pretty easily over LAN. At least with Teknoparrot it does. Assuming it's just regular LAN you would need a system to run TP running the game. And from there set the service menu options and cable the cabs together, possibly through a switch. The problem with this is that i'm not sure how the IO is connected. Even if it's just USB, there's no guarantee TP will know how to talk to it.
I'm not sure what the .dll file PL1 mentions above has to do with this. Sounds like it's going to spoof some sort of hardware identifier, or dongle? or it might just be an updated device library. This might help connect a different PC to an existing hardware setup, IDK.
Navigation
[0] Message Index
[*] Previous page
Go to full version
