Main > Forum/Website Discussion
a delete option
edekoning:
Its the internet, just accept that whatever you post will forever be. And this whole 'I can modify my posts' thing should also be disallowed or restricted. Really hate it when I am reading a thread, and someone nuked all his/her posts by modifying them all to a dot. Modify should just allow you to add stuff. Removing could then be done by applying strikethrough.
Malenko:
--- Quote from: edekoning on April 10, 2015, 07:18:08 am ---Its the internet, just accept that whatever you post will forever be. And this whole 'I can modify my posts' thing should also be disallowed or restricted. Really hate it when I am reading a thread, and someone nuked all his/her posts by modifying them all to a dot. Modify should just allow you to add stuff. Removing could then be done by applying strikethrough.
Modified should be used to fix posts, not remove them. You shouldn't punish the masses because a select few used the function improperly. It sucks when they do, but you just have to deal with it.
ark_ader:
I said it before and I will say it again. If you post something on the internet, just pretend you just submitted it to a newspaper or the Globe. You might get an editorial, but not a retraction.
wp34:
I've found missing images to be more of an issue than deleted posts. I can't stand it when the images from a thread are gone because they were hosted elsewhere.
Vigo:
--- Quote from: wp34 on April 10, 2015, 04:35:24 pm ---I've found missing images to be more of an issue than deleted posts. I can't stand it when the images from a thread are gone because they were hosted elsewhere.
Agreed. Not to mention, a lot of project pictures I can't see because my work filters out the photo hosting website.
Navigation
[0] Message Index
[*] Previous page
Go to full version
