Author Topic: Has anyone built 2 Vigolix? I'd like to build a vert and horizontal  (Read 13599 times)
Generic Eric
Has anyone built 2 Vigolix?  I'd like to build a vert and horizontal to be placed next to each other.  Any extra design considerations when having them placed side by side?
nitrogen_widget
Re: Has anyone built 2 Vigolix? I'd like to build a vert and horizontal
« Reply #1 on: October 27, 2014, 09:54:16 pm »
I'm considering doing this but making bar top versions.
  • Last login:April 15, 2026, 12:32:32 pm
« Reply #2 on: October 28, 2014, 10:16:14 am »
jdbailey1206
« Reply #3 on: October 28, 2014, 10:30:44 am »
Not to familiar with Vigolix cabinets but could you do a horizontal and create a rotating monitor?
« Reply #4 on: October 28, 2014, 11:04:58 am »
I think of all the cabinet designs, the vigolix lends its self the best to a rotating monitor set up.  That being said, if you want a vertical one just for the 4 way games, it'd be better to have 2 cabs.  I dont see why having 2 vigolix's side by side would be any different than any other cabs
« Reply #5 on: October 28, 2014, 11:14:39 am »
Didn't do vert and horizontal, but I did do 2 "matching" cabs.
Generic Eric
« Reply #6 on: October 28, 2014, 11:23:32 am »
 If I used the same Dell 1901FB monitor in each, does the bezel look to wide on the sides when I mount the monitor vertically?  Do I have to sacrafice marquee space?
« Reply #7 on: October 28, 2014, 11:38:21 am »
Just make the vertical cabinet skinnier.
« Reply #8 on: October 28, 2014, 12:05:34 pm »
Vigolix cabs were designed for 17 inch monitors though.  You'd have to mod the plans to make it fit.
D
nitrogen_widget
« Reply #9 on: October 28, 2014, 04:04:03 pm »
D
There isn't much to them though so you can modify them on the fly as you build.
I've picked up a flight stick from the late 80's at a thrift store (has a game port adapter on it) which means it's built fairly solid.
Same with my steering wheel from the the same era.
I could crank a few of these out using dedicated controls for each type of game.
I was building a cab out of pressure treated for my back porch.
got busy and when I had time to work on it again I wondered what id do with it in the winter since it's heavy as heck and while it's rough finish goes with the deck it will look like hell in the house. :)
My solution, vigolix bar top that slips into the cabinet on the porch when I have an outdoor party & can be easily brought in at night or the winter.
« Reply #10 on: October 28, 2014, 05:11:11 pm »
Wouldn't a Vigolix bartop just be a right triangle?  >:D
JDFan
« Last Edit: October 28, 2014, 05:20:24 pm by JDFan »
Generic Eric
« Reply #12 on: October 28, 2014, 05:27:05 pm »
There's a nice Vertical build by DrChek HERE -- http://forum.arcadecontrols.com/index.php/topic,119909.msg1277891.html#msg1277891
Indeed.  I was hoping to see them side by side though.  I may have to just do it.
I have the large triangle part cut, poorly.  I need to get a new saw yet.
« Reply #13 on: October 30, 2014, 12:18:47 pm »
I split the topics as requested.  Please keep any replies related to the original topic.
  • Last login:Yesterday at 07:04:52 pm
« Reply #14 on: October 30, 2014, 02:40:40 pm »
Have you considered doing a couple of Vigolix inspired bar tops to see how you would like a horizontal next to a vertical?
