Main > Main Forum
Speaker Sound Controls
TheOne:
Yep, that's the one I use.
thomas_surles:
I took apart the speaker and made a simple extention to the knob.
surface tension:
Just throwing in my 2c...
Similar to CabVol, you can use buttons if you're using a Minipac and assign +/-.
If you're set on using a pot, then as has been said, just extend the wire.
MamedInCanada:
Thanks for all the great options...I'm gonna open them up this weekend and see what I can do.
Thanks again!!!
MamedInCanada:
UPDATE:
I purchased the Logitech X-540 since it had a seperate control, removed speakers for front, center, and rear; filled in the old speaker holes, paint, drilled new holes, mounted the controller in the center for easy access, looks good...and thanks again for the ideas!
Navigation
[0] Message Index
[*] Previous page
Go to full version
