Main > Main Forum
Ultimarc Arcade VGA 3000 output to 2 monitors?
<< < (2/2)
SORHP:
--- Quote from: paigeoliver on February 10, 2014, 12:14:15 pm ---Consider swapping out that top Sanyo for a VGA monitor or an LCD. I am assuming you are just using it for a menu/extra stuff like Playchoice does then it won't really matter.
Also, it is totally your machine, but most people don't rip into $900 games to do their mame projects.
Thank you for the suggestion ;)
It shouldn't be this hard, I'm thinking I just need to use XP, the bottom monitor is the one I should be pulling, but the goal is not to pull anything... I completely restored this machine from the ground up, I repaired the board over the course of a month alone, as it stands, this machine converts to original in under 2 minutes with monitor adjustment ;)
I kind of hope with the original boards and and monitors and control panel, that it's worth much more than 900;$)
apfelanni:
some time ago i was in need of a cheap 15 k capable gc with dual analog output . i bought a radeon x600 with dms 59  plug + dm > double 15 pin sub d cable . installed win  xp and crt emudriver and it worked like a charm .
SORHP:
I'm going to have to remember that apfelanni! Thank you , as it stands, today I installed xp, arcadevga 3000, and used a video convertor for the top monitor, everything is working well, but it took most of the day, maybe someday down the road I'll be a little more brave and go the route you went;)
SORHP:
--- Quote from: apfelanni on February 15, 2014, 04:37:24 pm ---some time ago i was in need of a cheap 15 k capable gc with dual analog output . i bought a radeon x600 with dms 59  plug + dm > double 15 pin sub d cable . installed win  xp and crt emudriver and it worked like a charm .
Can you post a few links maybe?? Especially the driver you used?
apfelanni:
graphiccard like this one :
http://www.ebay.de/itm/109-A62931-OEM-Dell-ATI-Radeon-X600-128MB-PCI-e-/231158344357?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item35d21c6aa5
low profile or fullsize , dvi-dvi , dvi-analog or analog-analog breakout depending on what u need .
usually 10-20 bucks , best incl. the y-cable .
sofware : crt emudriver :
http://mame.3feetunder.com/windows-ati-crt-emudriver/
works with groovymame or any other mame version .
Navigation
[0] Message Index
[*] Previous page
Go to full version
