Main > Main Forum
Reccommendation needed for topcoat for MDF
mgb:
I don't think the fact that it has primer combined will hurt things.
stigzler:
OK - just to let others know for the future if in similar predicament.
Ended up going for Dulux Satinwood (water based) - got this mixed in B+Q (pick white off the shelf - choose your colour). Applied with Paint Sprayer so was a bit heart in mouth. Made sure thinned it enough for the sprayer first. Fantastic result - no runs - nozzle didn't clog - worked a treat.
Went for "Jet Black." Nice and solid - got chap in the store to put few extra dollops of the pigment in!
Only thing I'd advise is go for a 1 Liter can. I worried that wouldn't have enough + bought a 2.5l can. Did one entire pass on the cab and probably used 1/10th of the can!
Oh, also - choose your primer/undercoat well as well if spraying. On hindsight - think I chose a bad one to use with sprayers - nozzle/airjet holes kept getting clogged - dried paint in the nozzle felt latex-y.
Final finish wasn't piano-black smooth, but I quite liked it - uniformly slightly bumped (bit like the finish on coin doors) - gives it a nice solid looking texture. Like a hammered finish:
(This after one coat - coat 2 tomorrow!)
Hope this helps someone in the future!
mgb:
Looks great. Hopefully some more pics as you proceed.
I know what you mean about buying more than you need.
I used 3m water based adhesive when I put the laminate on my cab. It was $30 a quart and I wanted to make sure I didn't run out while laminating. Man, I only used about 3/4 of one quart for the whole cab. And I went two coats.
kahlid74:
--- Quote from: stigzler on November 19, 2013, 02:37:18 pm ---OK - just to let others know for the future if in similar predicament.
A few things, Latex can be applied again after the period on the paint can, usually 24 hours. What I mean by moving it is that ALL LATEX paint drys slower than oil, so it can take days for inner layers to dry. You're using a water based, which means it's latex. So don't move it. Most of the time it'll be fine, but sometimes you'll get a shift and boy will you be upset.
Never use primer in a spray gun unless it explicitly says it handles primer. Most spray guns you or I would buy from the store cannot handle primer, even latex primer. That is your issue with primer and your gun clogging. Primer always gets rolled on, regular paint can then get sprayed on unless you have a pro gun, and then you can spray primer. I also saw they now have consumer grade guns that "can" handle primer. I wouldn't honestly trust that but it might be fun to check into.
Glad to hear you like the end result. My $50 Wagner electric spray gun is the bomb as long as I follow the above. It's kind of a pain to have to roll primer on, but the end result is beautiful.
stigzler:
Thanks chaps.
Yeah, in retrospect, I think it was using the latex primer in my spray gun that produced the bumps on the finish. So.. lesson learned. However, as a stroke of enormous fortune, I quite like the hammered finish with the black and suits the theme of my cab.
My next is gonna be a white Wipeout cabinet. Now, for that, the finish has gotta be smoootthh.....
Navigation
[0] Message Index
[*] Previous page
Go to full version
