Author Topic: Sega Monaco GP 1979/1980 - My Remake  (Read 511002 times)
0 Members and 15 Guests are viewing this topic.
GPForverer2024
  • Last login:August 24, 2025, 09:43:10 am
Re: Sega Monaco GP 1979/1980 - My Remake
« Reply #560 on: June 24, 2025, 04:21:06 pm »
Hi Geecab!
Excellent news!  :applaud:
 I can't wait to see this video soon.
How lucky you are to be able to design projects like this!
 Bravo and thank you so much for sharing.
See you soon!
geecab
  • Last login:Yesterday at 02:43:05 am
« Reply #561 on: June 29, 2025, 04:27:13 am »
Hi GPForverer2024 and all!
Almost there! I have attached pics of the circuit I built, and a quick video (Its a pretty low quality video, I'll probably do a better one at some point).
All that remains is for me to tidy the code that enables this to run and write some instructions. I've made a new utility called "scoreboard_to_revcounter.exe". This runs on your PC, it reads the Rev values from a running MGPr game, and translates these to RPM values that get sent to the Arduino. I've also wrote a program that runs on the Arduino (Called arduino_rev_sim.ino) which receives these RPM values, and generates corresponding pulses to drive the physical revcounter. I'll provide the source code to both in a new MGPr package. It should be quite easy for anyone to modify scoreboard_to_revcounter & arduino_rev_sim to work with any game, not just MGPr. Hopefully I'll have this all ready and documented in a day or two.
The video shows scoreboard_to_revcounter.exe running in 'demo' mode, followed by it runnning in 'game' mode. In demo mode, MGPr doesn't need to be running, it just cycles though various RPMs so you can check you've specified the RPM range accurately. For example, I run scoreboard_to_revcounter.exe specifying an RPM range of 8000. Part 1 of the demo tests RPMs that increase at 25% steps of the range (0 RPM, 2000RPM, 4000RPM, 6000RPM and 8000RPM and back down). Part 2 of the demo tests RPMs that increase at 2.5% steps of the range (0 RPM, 200 RPM, 400 RPM etc...). If, say, I ran the demo and noticed the needle didn't quite reach the top of the range, I could specify a scoreboard_to_revcounter.exe RPM range to be something like 8100RPM until the needle hits the spot. When MGPr is running, scoreboard_to_revcounter.exe will convert MGPr's Rev value to an RPM proportional to your specified range. Hope that makes sense?
Regarding the circuit:
There are probably better ways to build this circuit (From what I read online, the TIP120 transistor and the 1N5400 diode are quite 'old' components these days, they can also handle lots more voltage/current that I'm going to put through them, so they're arguably a bit over-the-top). However, browsing for revcounter circuits, everyone seems to be using the TIP120/1N5400 arrangement and as these components are cheap and available, I thought I'd do the same.
I need to say a big thanks to 'tylerpeppy' who is a member of the Arduino forum. He's uploaded some very detailed Arduino projects to the site, including this revcounter one which I copied https://projecthub.arduino.cc/tylerpeppy/arduino-car-tachometer-simulator-no-simhub-f9fd0f. I actually used bits of his circuit diagram to make mine. My circuit is just a slightly rearranged version of his. You should be able to match my circuit diagram with what I built on the breadboard.
If you are buying a revcounter, be sure to get one that is compatible with a 2, 3, 4, 5, 6 or 8-cylinder Petrol engine, and runs off a 12v source.
I'm using a really old Arduino UNO board, but I think my arduino_rev_sim.ino program would run just fine on an Arduino Nano, Teensy board etc. (Anything compatible with the Arduino IDE, that you can upload *.ino files to should just work).
The Arduino sends the pulses to the revcounter out on Pin13. I picked Pin13 because it has an onboard LED connected to it. Thus without any circuit connected to Arduino, you can see the onboard LED flicker at a speed dependent on the pulses its trying to generate (So you can have confidence things are working before connecting it to any circuit). The pulses that output from the Arduino have 5v peaks. The revcounter needs a tacho source signal that has 12v peaks. The small Arduino signal pulses go into the base (B) of the TIP120 Transistor switching it on and off like a tap, As a result, the Transistor emits (E) larger 12v pulses.
There is no switch for the revcounter backlight light in the actual circuit I made (the yellow wire), its just permanently connected to 12v (I.e. Permanently on). But you could put a relay in there, switch the backlight on everytime you start a game perhaps?
You'll notice I'm using a 220 ohm resistor. Some people say use a 2.2K ohm resistor but it really doesn't matter. I've tried both and everything works fine. The resistor isn't there to protect the transistor, it is there to reduce current drawn from the Arduino. If you've got loads of other stuff connected to the other Arduino output pins then saving current might be important. As I've only got 1 output pin in use, this isn't a concern.
The legs of the transistor and diode were so thick I couldn't push them into my bread board. That's why you'll see I soldered thin wires to their legs.
The Diode (Which, at first, looks like its been placed the wrong way round) is there to protect the transistor when the +12v PSU is unexpectedly powered off. In normal operation (Where the +12v source is either greater than or equal to the Tacho source signal) the Diode acts as if it were open circuit. Should, however, the +12v supply be switched off when the revcounter is in full swing, then the Diode will conduct. Apparently, some revcounters act like inductors and build up charge. When the +12v PSU is unexpectedly powered off, the diode ensures any built up charge is routed away from the transistor and thus protecting it.
Regarding my KET105 Revcounter/Tachometer:
I do think it looks good and its needle movement is just about fast enough. The cylinder switch at the back (Allowing you to choose between 2,3,4,5,6 or 8 cylinders) works well.
Something worth mentioning (That I believe is quite common with most off-the-shelf revcounters), is that they have trouble reading very low RPMs. My revcounter needle moves oddly (bounces around) when you send it less than, 600 RPM at 2-cylinder. This is probably OK as most engines would stall if you tried to run them this slow. I did notice increasing to 8 cylinder vastly improved things (Where you'd only see the oddness starting at less that 150RPM. I worked around this in my software, you can set a 'Stall RPM' where anything below a particular RPM will just send no pulses to the revcounter (and its needle will just drop to zero).
Wow, probably too much information here! Well done if you made it to the end! :)
« Last Edit: July 01, 2025, 04:09:03 am by geecab »
GPForverer2024
« Reply #562 on: June 29, 2025, 09:57:32 am »
Hi geecab!
What incredible work!!!
I'm amazed to see this result!
I'll send you a link to see if I can order this rev counter so it's compatible with your software, and I'll order the rest of the equipment.
I'm waiting for your reply.
Thank you, I can't wait.
https://a.aliexpress.com/_Eu4slUw
geecab
« Reply #563 on: June 29, 2025, 11:50:11 am »
Hi geecab!
Hi GPForverer2024! Its looks excellent, great price too! Its 12v, and supports 4,6,8 cylinders, the wiring looks the same too. The only thing I'd mention is that it doesn't specifically state its for Petrol or Diesel engines. It does state its "Universal" so I guess that's OK? For that price its kind of worth a punt :)
« Last Edit: June 29, 2025, 12:06:58 pm by geecab »
geecab
« Reply #564 on: June 29, 2025, 12:06:35 pm »
OK, I've just read online that "Petrol revcounters work from electrical pulses taken from the ignition system. Diesel often work from the end of the alternator, mechanically or by pulses from a crank sensor".  The wiring diagram for your revcounter shows simply the green signal source wire going to the ignition coil. So I think its designed to work with petrol engines, so it should be fine with my circuit :)
GPForverer2024
« Reply #565 on: June 29, 2025, 12:21:11 pm »
Hi Geecab!
Thanks for your quick response.
I've ordered all the equipment.
See you soon.
geecab
« Reply #566 on: June 29, 2025, 12:28:26 pm »
Great stuff GPForverer2024!
I've put together debug version v1.5.1D3.
****EDIT: This version is now obsolete, please see initial post (on page 1) for download links to the latest version****
This debug version has the following modifications:
 - Added new Scoreboard To Revcounter utility source code and exe (Reads MGPr game Revs, and sends them to Arduino).
 - Added Arduino sketch "arduino_rev_sim.ino" (When running on an Arduino, it receives RPM values and generates a series of pulses as output).
« Last Edit: December 06, 2025, 12:20:10 pm by geecab »
geecab
« Reply #567 on: July 01, 2025, 04:16:56 am »
Hi GPForverer2024!
Whoops! I've found a bug in in my scoreboard_to_revcounter util (It was the reason for the strange RPMs I was seeing when I'd set my revcounter cylinder switch to 3,5,6 or 8-cylinder).
I actually think my KET105 revcounter is a good bit of kit now. I've modified the big post I wrote on Sunday to paint it in a better light.
I'll upload a new MGPr package in the next few days that has the fix :)
Swainy
  • Last login:March 14, 2026, 05:15:06 am
« Reply #568 on: July 01, 2025, 06:55:07 am »
Hi geecab,
I switched on the high score table on my set up last night (only spotted that feature when I was watching through some of your videos. Anyway, when I was pressing my accelerator pedal to select a letter, it wasn’t working. I have to have my pedal selected as inverted in the game options to get it working in game. Just thought I’d mention it so you can add it to the fix list. Cheers!
geecab
« Reply #569 on: July 01, 2025, 01:13:36 pm »
Hi Swainy!
Thanks for letting us know, I'll get that fixed in the next package. In the mean time, if you have a button configured as the 'Start' button (I think its the '1' key by default), you should be able to press that to select a letter.
GPForverer2024
« Reply #570 on: July 02, 2025, 03:24:53 am »
Hi Geecab!
No worries.
I'm waiting to receive my equipment.
I can't wait to try it out! See you soon.
geecab
« Reply #571 on: July 02, 2025, 03:57:07 am »
Hi geecab,
Hi Swainy!
Just done a quick test with my analog pedal but this seems to be working for me. Can I just double check your config settings are the same as mine:
    ACCELERATOR_DEVICE = "KEYBOARD/MOUSE/JOYSTICK STICK Y AXIS"
    ACCELERATOR_INVERT = "YES"
    ACCELERATOR_RANGE = "-1 to +1"
Also, please can you let me know what MGPr package version you are running, and also the name of the configuration file you are modifying.
BTW. To choose a letter when entering your name, you have to press and then release your pedal (Not just hold it down), its needs to see a complete 'press' if that makes sense?
geecab
« Reply #572 on: July 02, 2025, 04:28:08 am »
Hi Swainy!
Me again! I think this is something I fixed last year, just checked the v1.5.1 package and the accelerator is broken during the Enter Your Name section as you describe. Sorry, I should have realised this earlier.
If you are running windows, you could try the debug version v1.5.1D3 I recently uploaded. I think it should be fixed in there.
Swainy
« Reply #573 on: July 02, 2025, 03:16:40 pm »
Hi Swainy!
Yep, that is working lovely! Cheers mate!
geecab
« Reply #574 on: July 05, 2025, 06:28:25 am »
Hi GPForverer2024 and Swainy!
I've put together another debug version v1.5.1D4.
 - Fix bug in Scoreboard To Revcounter utility that was giving strange
   RPMs readings if you had set a cylinder value to 3, 5, 6 or 8 cylinder.
 - When the Enter Your Name screen first appears, ensure the player is off the
   gas before we start detecting pedal presses.
@Swainy - Just letting you know (No need to try this debug version if you're happy with v1.5.1D3) - I've fixed another silly bug I noticed when trying to recreate the Pedal/EnterYourName issue you mentioned before. That was, if I was stepping ON the gas just when the EnterYourName screen appears, then as soon as I stepped OFF the gas a letter would be selected (Which was too soon). Letter selections happen when the gas pedal moves from the ON to the OFF position. I've fixed this by waiting for the gas pedal be in the OFF position before I start detecting letter selections. Hope that make sense, probably too much information lol!
« Last Edit: December 06, 2025, 12:17:41 pm by geecab »
GPForverer2024
« Reply #575 on: July 13, 2025, 06:04:04 am »
Hi Geecab
I'm just giving you some news.
I'm missing a component to start the rev counter.
I expect to receive it next week.
 I'm really looking forward to it.
 See you soon.
geecab
« Reply #576 on: July 13, 2025, 01:42:30 pm »
Hi Geecab
 See you soon.
Cheers for the update GPForverer2024! Hope it all goes together smoothly and works first time! :)
GPForverer2024
« Reply #577 on: July 18, 2025, 03:07:46 am »
Hi Geecab!
Here's the news:
Everything is connected, the speedometer lights up and is set to 8 cylinders.
When I launch the revcounter file with the correct  com port, it says "Arduino connected OK."
Then it can't find the game, which is launched, and then closes automatically.
Then I saw in your release notes that I had to set the game settings to "Scorboard to Export."
And now the game won't launch.
I think it's a configuration issue in the game.
Could you send me another example .bat file? For launching both programs?
I'm really sorry, I would have loved to tell you that it works the first time.  :-\
Thank you so much.
geecab
« Reply #578 on: July 18, 2025, 08:22:30 am »
Hi GPForverer2024!
>>Everything is connected, the speedometer lights up and is set to 8 cylinders. When I launch the revcounter file with the correct  com port, it says "Arduino connected OK."
Sounds good!
Ah, I think we had a similar issue when trying to get the scoreboard_to_relays tool working on your system? Can you make sure that mgpr.exe and scoreboard_to_revcounter.exe are both running in administrator mode? I really should have stated this in the release notes, sorry, lets hope that's all it is :)
GPForverer2024
« Reply #579 on: July 18, 2025, 09:25:31 am »
Yes,
 I can confirm that both files are launched in administrator mode.
geecab
« Reply #580 on: July 18, 2025, 09:59:49 am »
Hm, it has to be a problem with scoreboard_to_revcounter.exe not being able to see the shared memory that mgpr.exe creates.
Lets forget about scoreboard_to_revcounter.exe for a moment...
Can you run the dualscreen_pro_monaco_gp.bat file. That should automatically start an instance of mgpr.exe in export mode (for which you'll see a window with the game running in) an instance of mgpr.exe in import mode (for which you'll see a window with scoreboard information in). If these 2 instances run ok (I.e. you can play the game in one window, and see your scores and revcounter change in the other window), we know the shared memory is being exported ok.
GPForverer2024
« Reply #581 on: July 19, 2025, 03:27:31 am »
Hi Geecab!
You were right.
I followed your advice by first launching the dual screen.
It didn't work.
After several searches, it was Windows that was blocking the application (for your information, all these new tests were done on another PC, not the one with my console).
Once the dual screen was launched, I manually launched my scoreboard rev counter .bat file with the following configuration:
scoreboard_to_revcounter .exe 10 game 8 8000 600
And to my great joy!!!! It works, wow!!!!
Great Geecab.   :applaud:
 Thank you, thank you, thank you!!
After several tests, only cylinder 8 works best.
However, the only drawback is that the needle rises too quickly, and when the car crashes, there's a delay before the needle returns to zero.
 Otherwise, congratulations, Geecab, once again, what an incredible job!
Looking forward to hearing from you soon.
geecab
« Reply #582 on: July 19, 2025, 04:53:18 am »
Excellent stuff GPForverer2024!
Congratulations regarding your electronic skills, so happy you've got it working!!
Interesting. It sounds like your revcounter needle response time is much faster than mine. I can add an option to scoreboard_to_revcounter, so you choose a percentage that effects how much we 'dampen' the needle response time. Shouldn't be too tricky to do. I had to do that for the game's graphical revcounter because its needle response was obviously instantaneous (and looked like its was snapping to positions at first).
This is interesting too. I'm guessing the type of crash you are talking about is one where your car hits something and goes into spin, rather than one where you hit something and explode?
Do you see the same thing happen with the game's graphical revcounter (Or perhaps its not as noticeable with that because of the way I've dampened its needle response)?
GPForverer2024
« Reply #583 on: July 20, 2025, 12:00:47 pm »
Hi Geecab!
Yes, it would be a good idea to add an option for the needle speed.
And yes, there is a latency for the accident involving the car spinning out.
not easy to see with the graphic outline on the second screen for me it works correctly
 Quick question: what's the purpose of the last number in the rev counter file (150, 600, etc.) for the configuration?
Thank you very much.
GPForverer2024
« Reply #584 on: July 20, 2025, 01:21:44 pm »
Geecab for info I sent you a private message
geecab
« Reply #585 on: July 21, 2025, 03:52:00 am »
Hi GPForverer2024!
I seem to have problems on this site with some of my PMs not being delivered, so I've responded here...
What type of Arduino board do you have? I've got a really old Arduino UNO which has a CPU running at 16MHz, you might be using a newer board which is running a faster CPU speed (Which would explain why its outputting pulses faster than mine)? I'd need to modify the code a bit to cater for different Arduino boards if that is the case.
For the time being, may I suggest trying the following parms when running scoreboard_to_revcounter and seeing what happens (Basically, reduce the value of the rpm_range parm to 6000):
    scoreboard_to_revcounter .exe 10 game 8 6000 250
It is a bit confusing I must admit. Have a look in the release_note.txt for the description of "rpm_stall". Basically, most revcounters won't be able to read low RPMs beyond a certain point. Once you go lower than that RPM, the needle may jump around strangely (mine does lol!). For my revcounter, when switched to 2 cylinder the strangeness begins at 600RPM or less. When switched to 8 cylinder, the strangeness begins at 250RPM or less. So it seems 'better' to have the cylinder switched to the highest value possible, to give you the best range.
The rpm_stall value is the lowest RPM your revcounter can handle before the needle starts acting strange. When the game attempts to set an RPM lower than the rpm_stall value, this will cause the arduino to output no pulses (So the needle will just drop to 0 RPM, like the engine has been switched off, avoiding any needle jumping strangeness).
Now it may be the case that your revcounter it better than mine, and won't do silly things at low RPMs. You could try setting the rpm_stall value to 0, so you can see what happens at these low RPMs.
GPForverer2024
« Reply #586 on: July 21, 2025, 10:22:48 am »
Hi Geecab!
For your information, my Arduino Uno SMD 16 MHz board is new.
I just tried your setup:
And it's actually better, but not quite there yet.
Let me explain:
When I drive the car in first gear, it's smooth, with the graphic rev counter sync on my second PC screen.
 As soon as I shift into second gear, I noticed a lag between the graphic rev counter on the second PC screen and my physical rev counter.
That is, the needle syncs up to 3 and 30 on the graphic, then after that, there's a lag of 0.5, that is, 4 on the rev counter and 3.5 on the graphic rev counter, etc., up to 8.
I also noticed that the needle on the physical rev counter jerks from 5 up to 8.
I hope I've been as clear as possible and that this can help you.
See you soon.
geecab
« Reply #587 on: July 21, 2025, 05:28:06 pm »
Hi GPForverer2024!
OK, thanks for this. Its a mystery as to why your revcounter is reading more revs than I expect...
Can you let me know how do you set the cylinder value on your revcounter (Is there a switch at the back)? Also, what cylinder values are you able to switch it to?
When you get the chance, please can you do the following test (You don't need to have MGPr running for this). Run scoreboard_to_revcounter like this (Note. the 'set' command will output a continuous RPM):
    scoreboard_to_revcounter.exe 10 set 8 3000 250
While that's running, switch your revcounter to 4-cylinder, 6-cylinder and 8-cylinder and let me know what RPMs are shown for each of those (FYI. My revcounter shows exactly
6000RPM (4-cylinder), 4000RPM (6-cylinder), 3000RPM (8-cylinder)).
Many thanks,
GPForverer2024
« Reply #588 on: July 22, 2025, 01:11:13 am »
Hi Geecab!
 The cylinders are adjusted on the front of the speedometer with a dial.
You can choose two, three, four, five, six, seven, eight.
Then, if I run the command:
 And I just change the cylinder value on the rev counter, it displays the same value of 4.45 on the rev counter for cylinders 4, 6, and 8.
cylinder 8 = 4.5 rev counter
scoreboard_to_revcounter.exe 10 set 6 3000 250
cylinder 6 = 3.3 rev counter
 cylinder 4 = 4.2 rev counter
 I hope I've been clear enough to help you.
Thank you very much, Geecab.
GPForverer2024
« Reply #589 on: July 22, 2025, 01:15:15 am »
scoreboard_to_revcounter.exe 10 set 4 3000 250
Cylindre 4=4,2 rev counter
geecab
« Reply #590 on: July 22, 2025, 02:39:38 am »
HI GPForverer2024!
Thanks for doing those tests. I think we are close to solving part of the mystery :)
>>The cylinders are adjusted on the front of the speedometer with a dial. You can choose two, three, four, five, six, seven, eight.
I don't think that dial switches the cylinder. I think that dial just sets when you want the "Shift-Light" to illuminate.
The fact that the RPM stays same means the cylinder of the revcounter is not being switched. It appears to be fixed to 6-cylinder.
I've just had another look at the aliexpress advert for your revcounter, you should only be able to switch your revcounter to 4, 6, or 8 cylinder, and there is a switch on the back for this? Please can you double check this.
GPForverer2024
« Reply #591 on: July 22, 2025, 08:59:23 am »
Hi geecab!
I can confirm there's no switch on the back. I even unscrewed the back cover, thinking there was a switch underneath, but there's nothing at all.
 I'm really sorry.
geecab
« Reply #592 on: July 22, 2025, 03:09:36 pm »
Hi GPForverer2024!
Interesting stuff, is there anything helpful written in the instructions you got with it?
I've just been google-ing, this revcounter looks a bit like yours, and you switch cylinders by holding down (for 6 seconds) the little button that's in-between the Dial and the Shift-Light:
https://www.amazon.com/MH-Tachometer-0-8000-Large-Dashboard/dp/B0DSVVNXBN?th=1
Can you give that a try?
GPForverer2024
« Reply #593 on: July 23, 2025, 02:58:38 am »
Hi Geecab!
Congratulations again!
 You've found it!
You have to hold down the light button on the front panel for 6 seconds, then briefly click on it to select your cylinder!
So I redid the tests:
Cylinder 4 = 6.8 rpm
Cylinder 6 = 4.4 rpm
Cylinder 8 = 3.3 rpm
For your information, I also noticed that the needle drops too quickly.
I hope I was as clear as possible and that this will help you.
GPForverer2024
« Reply #594 on: July 23, 2025, 03:02:20 am »
Sorry,
I also forgot to tell you that I launched the command:
Scoreboard_to_revcounter.exe 10 set 8 3000 250
geecab
« Reply #595 on: July 23, 2025, 11:47:29 am »
Its sounds like your revcounter reads a little higher that it should, but that's fine. We'll just reduce the scoreboard_to_revcounter's rpm_range value to compensate.
So can you now do the following,  switch your revcounter to 8-cylinder, then run this:
    scoreboard_to_revcounter.exe 10 demo 8 8000 250
An MGPr instance doesn't need to be running when using the 'demo' command. When you run the above you'll see the needle climb to 8000RPM in 2000RPM steps (rpm_range/4), then afterwards the needle will climb 8000RPM in smaller 250RPM (rpm_range/32) steps. You can see this 'demo' running at the start of my video I posted a while back. As we expect, your revcounter's needle will point to a value a bit higher than it should each time. So you should experiment lowering the rpm_range setting from 8000 to say 7800 (i.e. scoreboard_to_revcounter.exe 10 demo 8 7800 250) to compensate, until the needle lines up with markings on your revcounter gauge. If things appear to line up when specifying a range of 7800, then that's the range your want to specify when you are running MGPr. I.e.:
    scoreboard_to_revcounter.exe 10 game 8 7800 250
Make sense? I'm probably over complicating this lol!
Regarding what you said about the needle sticking/jerking around 5000RPM, do you still see this when running the demo?
Have another look at my video and compare the speed of my revcounter needle when I crash, or change from Lo to Hi gear. Are we saying that your revcounter needle drops faster than mine at those moments? If so, I have a new version of scoreboard_to_revcounter and arduino_rev_sim.ino that I think will sort this.
« Last Edit: July 23, 2025, 12:02:05 pm by geecab »
geecab
« Reply #596 on: July 23, 2025, 02:02:32 pm »
Hi GPForverer2024!
Following on from my last post, I've put together debug version v1.5.1D6.
 - arduino_rev_sim.ino has new DAMPING setting (The default value is 75%. Increase this value if your revcounter needle is moving too fast).
 - arduino_rev_sim.ino now considers CPU speed of the Arduino board type when producing pulses.
If you want to change the DAMPING value, you have to edit the value in arduino_rev_sim.ino, then upload it to your Arduino.
I've had to modify scoreboard_to_revcounter.exe too to get the damping working, so you'll need to be sure your scoreboard_to_revcounter.exe and arduino_rev_sim.ino you are using are both from this new package.
Hope this helps!
« Last Edit: December 06, 2025, 12:18:32 pm by geecab »
GPForverer2024
« Reply #597 on: July 24, 2025, 02:33:26 am »
Hi Geecab!
First, I changed the rpm value to 7800 to get the needle as close as possible to the number on the speedometer.
Then I increased the damping to 85% in the Arduino-rev.sim.ino file and uploaded it.
The needle speed is now much better and similar to yours, according to your video.
And yes, after 5 rpm, the needle goes up, then down 3 bars, then back up again.
For your information, I sent you a private message.
Thanks Geecab.
geecab
« Reply #598 on: July 24, 2025, 01:15:03 pm »
Hi GPForverer2024!
Thanks for the PM, I see what you mean regarding the jerky needle from 5000RPM and upwards. I sent you a PM in response with a few other tests to try.
I just decided to take a closer look at the needle on my revcounter when I ran the demo, and I do see the same jerkyness but not as obvious as it is with yours.
So I decided to change my Arduino code to output a square wave instead of pulses, and afterwards I noticed my revcounter needle is completely stable. So I'm hoping this will also improve the situation for you.
The new version of arduino_rev_sim.ino can be downloaded HERE.
Hope it helps!
GPForverer2024
« Reply #599 on: July 25, 2025, 02:53:05 am »
Hi Geecab!
I ran several tests at your request, and I can tell you,
thanks to your latest modified Arduino _rev_sim.ino file, it's practically perfect. Wow!!!
 I had to increase the damping in your file to 95 because in first gear, the needle was rising too fast compared to the graphical rev counter.
Here's my command line:
 scoreboard_to_revcounter.exe 10 game 8 8300 0
 I increased the RPM to 8300 because in second gear, it was lagging behind the graphical rev counter, and what's more, it didn't reach 8 RPM at full throttle.
This is a top modification!
Great work, Geecab.  :applaud:
 I just noticed a small, not too serious detail, but the needle has trouble at low revs.
Let me explain: if I accelerate and slow down, the needle stops at 1 rpm, which is normal.
However, if I have an accident with the car, the needle should drop to 0 rpm, and then it stops for about 1 second at 0.5 rpm, then 0 rpm, when it should drop directly to 0 rpm.
I hope this helps you with this small detail, otherwise, really great work, once again, Geecab!
I really admire the work done, well done Geecab. :applaud: :applaud:
