Main > Main Forum
touchpad to control music
<< < (2/2)
severdhed:
accidentally double posted and don't know how to delete it...please ignore
Caparo8bit:
--- Quote from: severdhed on September 04, 2013, 11:20:18 am ---I agree... make a cardboard mockup of your panel and see how it feels.
Here are some thoughts on admin buttons..
I highly advise against a power button on your control panel, it will get pressed accidentally and it will piss you off when it happens.
What is the home button for?
Do you plan on having a pause button?
I'd keep the start buttons away from any admin buttons to avoid confusion. You know what the buttons do, but other people will not.
home button is to exit emulator to emulator menu / maximus arcade (esc. only exit rom)
HanoiBoi:
I don't quite understand the touchpad thing.  Does it do more than just control music?  It seems odd to me to be included on the CP.
Do you have a coin door?  If not, you might want coin buttons.
Are you locked in to the size and shape of the CP?  As mentioned, its a lot of real estate for what you need for controls.  You could probably clip the CP width by 8-12 inches.
Also as mentioned...the power button.  I'd suggest moving that off the CP altogether.  If not, kids will push it on purpose, adults will push it by accident.
BTW, is this a pedestal build?
Caparo8bit:
--- Quote from: HanoiBoi on September 05, 2013, 06:49:36 am ---I don't quite understand the touchpad thing.  Does it do more than just control music?  It seems odd to me to be included on the CP.
touchpad works as a mouse and kboard. main use to control musicbee and i have a showcase comes in two parts working on pedestal right now check my pictures below.oooh and for de coins or credits i hacked the coin ejectors
Caparo8bit:
--- Quote from: yotsuya on September 04, 2013, 02:47:57 am ---What's the difference between Home and Esc?
And I'd put P1 and P2 lower, in place of Home and Escape. You don't want anyone reaching OVER Esc to press anything and accidentally exit you out.
home  takes to emu menu    esc exit rom and  still on same emu.  (maximus arcade)
Navigation
[0] Message Index
[*] Previous page
Go to full version
