Main > Main Forum
new using j-pac (Solved)
<< < (2/2)
Caparo8bit:
--- Quote from: paigeoliver on August 06, 2013, 11:06:51 pm ---
--- Quote from: Caparo8bit on August 06, 2013, 10:16:48 pm ---ok so now every time a connect the usb from the j-pac (PC KB/USB) in to my laptop usb  for some reason the computer starts tapping q569 q569 q569 and wont stop............. :angry:  help please
You probably have those inputs shorted in your arcade wiring.
yeah found them tysm
PL1:
Thank you.   :cheers:
--- Quote from: Caparo8bit on August 07, 2013, 12:56:23 am ---ground cable was on ( NO) and and 2nd cable was on (com)
Looks like you were using part of my "backward" wiring trick.
More on a similar, but larger-scale related wiring technique soon. . . . Right, Jon?   ;D
Caparo8bit:
--- Quote from: PL1 on August 07, 2013, 01:30:12 am ---Thank you.   :cheers:
......was like that. I bought it from a guy and idk if I over pay $200 is a show case 33" deluxe  snk vs stf  I'm taking arcade monitor out  cant make it work with my laptop ( widows 7  hd intel graphics) if you pay delivery monitor is all yours ... I'm planing to use LED 32" ( stretched picture) to get full screen . Lepai 2.1 amp. My next step is map c. Panel to Maximus arcade... Any idea how......?
PL1:
Are you sure you want to get rid of the monitor?
Instead of a laptop, you can use a cheap PC to get it up and running.
BTW, the thread offering the monitor for trade should be in the Buy/Sell/Trade forum.
Caparo8bit:
--- Quote from: PL1 on August 07, 2013, 04:37:46 pm ---Are you sure you want to get rid of the monitor?
  cheeeeeeeeezzzzzz  :o i just removed the monitor few mins ago and is heavy as helllllll.....!and yeah i have a 32" led sitting in the garage and i like how mame looks using hdmi from pc/led  . shiping must cost $$$$$$$$ lots...
Navigation
[0] Message Index
[*] Previous page
Go to full version
