Author Topic: 6 volt bulbs  (Read 1204 times)
eclipso
  • Last login:August 21, 2018, 08:51:25 am
6 volt bulbs
« on: April 28, 2013, 09:53:37 am »
So I need to replace the bulbs in my KI coin door so I opened up the book and found they are 5.9v bulbs with .6 amps however when I go to find some on e-bay there are alot of choices. I think these might work but would like to make sure and be safe then sorry.
http://www.ebay.com/itm/63-CLEAR-BULB-10-PACK-/120370287779?pt=LH_DefaultDomain_0&hash=item1c06a0d4a3
lilshawn
  • Last login:Today at 12:18:29 pm
Re: 6 volt bulbs
« Reply #1 on: April 30, 2013, 02:59:43 pm »
that was probably originally an 1850 bulb. (5v, 90ma) but anything in the 6 volt range should work okay...#755 etc.
heck, search ebay for some 5 or 6 volt LED bulbs with a "bayonet" style base also known as a "BA9S" size base and be done with it forever.
the #63 you've chosen will probably work alright. depending on the current going out to them from the harness they might be a tiny bit dimmer than the original. not enough that you'd notice. but it's better than burned out right?
