Main > Main Forum
Question regarding Plexiglass
shponglefan:
Do you already have the T-Molding? Looking at T-Molding.com, they have 13/16 inch and 1 inch sizes. That means you'd need either 1/16 inch Plexi (which is pretty thin), or 1/4 inch plexi to accomodate those sizes of T-Molding.
Alternatively, you could round the bottom of the 3/4 MDF so the height at the edges is 5/8 and then use 1/8 plexi and 3/4 T-Molding. IMHO, 1/8 plexi is the easiest to work with and 3/4 inch T-Molding has the most options (colours, etc).
Or another option is to just redo the panel with 5/8 MDF and use 1/8 plexi per the above.
Yourname942:
nah I don't have the T molding yet.
What would be the better option to use 1/16" or 1/4" plexi for:
- control panel
- bezel cover
- marquee cover
I appreciate the help.
shponglefan:
It depends on what is behind them. 1/16 inch will be extremely flexible*. So you want a solid surface to brace it against. For a CP, this is not an issue. And thinner plexi will make it easier to cut and drill out the necessary holes.
But for something like a marquee, if you have a light-up marquee, you probably won't have a solid surface behind it. So 1/4 inch would be better in that case.
* Just as a disclaimer, I've never worked with anything quite that thin. Thinnest plexi I've used is about ~0.08 inch, which is pretty close to 1/16th.
Yourname942:
Alright, ty. I think I'll just stick with 1/4 plexi for all the parts.
Dawgz Rule:
For the bezel I would recommend glass over plexi. Graylite 31 will really make the colors pop. Also, it is less prone to scratching.
Navigation
[0] Message Index
[*] Previous page
Go to full version
