Main > Main Forum
Casters on a Dynamo Cab
ChadTower:
Probably, if you put it on those cross braces on the outside, but can't tell for sure without looking at the inside.
One thing to note is that casters DO make the thing wobble a little bit during play. The wheels only make a little bit of actual contact with the floor so if it's a game that has a lot of pulling/pushing the cabinet will move a small amount.
brained:
Probably I can do something like the image i'm posting here (googled it). Or maybe I can hack the corner leg leveler to fit the casters
This are the leg levelers my arcade has.
http://thearcadeboneyard.com/cabinet_parts/images/dynamo%20hs5%20cabinet%20leg%20leveler%20and%20plate%2018.JPG
brained:
bump! :)
Zeppo:
I cut a piece plywood to cover the bottom, then mounted casters on that.
Works great.
brained:
Thanks Zeppo, I think I will use your suggestion.
Navigation
[0] Message Index
[*] Previous page
Go to full version
