Software Support > GroovyMAME
No sound in many games in groovymame? (HD4350 related? CRT_Emu?)
<< < (20/20)
Endprodukt:
I will get in touch with the people who made my UMSA.
Thanks for all the support... whish I would have tested with my headphones earlier...  :banghead: :banghead: :banghead:
Endprodukt:
So, THEY say, the UMSA can't be the problem because it's just sending the sound to the TV without touching it. So... the last piece in the chain would be the TV itself. Is this even possible?
krick:
I guess it's possible.
Do you have access to an other SCART capable TV to test with?
It could also the cable between the UMSA and your TV.
Do you have access to another cable, possibly from a different manufacturer for testing purposes?
Endprodukt:
Got a new cable today, tested with another TV set and it seems to be the TV causing the problem. That's why I couldn't identify the UMSA as the problem in the beginning. I guess I can't do much about that but have to get a new TV.
Calamity:
--- Quote from: Endprodukt on September 12, 2012, 04:50:51 am ---Got a new cable today, tested with another TV set and it seems to be the TV causing the problem. That's why I couldn't identify the UMSA as the problem in the beginning. I guess I can't do much about that but have to get a new TV.
 :o
That's the most unexpected result ever. I'm glad to see that at least you could find the source of the problem.
Navigation
[0] Message Index
[*] Previous page
Go to full version
