Author Topic: MVS-4: AC switch to power supply confusion  (Read 2449 times)
Arcade-TV
  • Last login:September 17, 2019, 04:50:47 pm
« on: May 31, 2012, 05:46:40 am »
Hey guys,
I got a MVS-4 cabinet a while ago and finally started to work on it.
There where two complete harnesses inside and a lot of cables where a mess so I decided to remove all the wiring and doing it nice and clean.
as for the wiring, that's no problem... what's freaking me out is the power supply and the wire which goes from there to the main AC switch behind the coindoor. These were cut off and even having the wiring diagramm from the service manual, I have no clue how these go together.
Here are some pictures of my situation:
https://picasaweb.google.com/115948745418514736250/MVS4?authuser=0&feat=directlink
can anybody explain to me or show me a picture of his wiring?
Thanks guys, your help is very much appreciated!
-Alex-
edit:
I noticed that I seem to be missing a cable coming from the psu, though the 4Pin-connector leading to the AC switch is present but not connected to my psu.
Maybe I have a different psu model, it seems there is one with external power on/off functionality... Mine does have a button for on/off where the cable should be...
I will see if I can modify this button and connect the leads to it...
« Last Edit: May 31, 2012, 08:48:42 am by Arcade-TV »
Arcade-TV
Re: MVS-4: AC switch to power supply confusion
« Reply #1 on: May 31, 2012, 11:35:16 pm »
I got it.
I removed the switch from the psu and connected the leads to the 4pin molex.
works great :)
