Main > Main Forum
26 inch cabinet??
Brian74:
I used a wall mount on a piece of wood.
knohbody:
Maybe you can tilt the wall mount? Otherwise you'll have to change the angle of the wood. Before you do that, find the angle you want the monitor to be at and how it relates to the mount.
TopJimmyCooks:
Advice still applies. try flipping the problem display upside down, lcds are usually good one way and bad the other. In your pic the bottom monitor seems good, the top one seems washed out.
kahlid74:
Try what TopJimmy suggests. I've seen that resolve numerous issues with LCDs. The wall mount is nice because you can change the angle on the LCD but the big issue is that the cavity it fits into might become off centered.
Brian74:
Well it was the bottom one I was having probs with. I took your advice and flipped it and it looks great! Thanks so much! Im going to try flip the top one and see if that helps that one. The bottom one was the one i was really worried about. Its going to be cool to play future pinball having the back board right above. If the cab was little wider I could have tried to rotate it. Thanks again everyone for the help!
Navigation
[0] Message Index
[*] Previous page
Go to full version
