Software Support > GroovyMAME
Sound stuttering only at 320x240
<< < (3/3)
Calamity:
--- Quote from: blagger on December 13, 2011, 07:50:26 am ---After enabling both flipx and flipy the vertical games are now displayed correct.
But unfortunately the horizontal games now upside down.
Those flip options should only be active in vertical mode, not horizontal.
Is there a solution to this problem?
The problem there is that it's forcing -ror where it should allow to decide between -ror and -rol. I'll need to fix that in next version.
A possible workaround is to create a file named vertical.ini and add those flipx & flipy settings inside (check MAME doc for more info on this).
--- Quote from: Calamity on December 13, 2011, 06:04:28 am ---I did have the CCC, but I couldn't get any output to the secondary monitor.
But I will try it again, maybe I made some mistake back then.
That's possible, I need to update the driver packages with a possible fix that was not available when you tested them. I'll let you know.
blagger:
--- Quote from: Calamity on December 13, 2011, 08:21:07 am ---
I just tried using vertical.ini and horizontal.ini and this works now.
Thanks a lot for your help.
Navigation
[0] Message Index
[*] Previous page
Go to full version
