Software Support > GroovyMAME
Sync issues with Nanao MS9
<< < (6/6)
Calamity:
--- Quote from: blontic on June 22, 2012, 09:12:45 pm ---Hi I was hoping you could help me, I have a Nanao MS8 which supports 15/25hz but manually only. I only want to leave it in the 15hz position so does that mean I only add the monitor_spec_0 line to my vmmaker.ini file?
Also when I run a 25hz game will it display interlaced if I set a ini file for the game? Or can I not run 25hz games?
Thank you.
Yes, if you want to leave the switch in the 15 kHz position then you're not going to be using the 25 kHz range, so you must not add the corresponding monitor_specs line.
If you're using GroovyMAME, you shouldn't use inis for forcing explicit resolutions.
With this setup, GroovyMAME will automatically pick the best interlaced mode for 25 kHz games.
blontic:
Great, thank you for the updates. What's the best resolution for desktop if I don't want it interlaced? And what software do I use to set it?
blontic:
Calamity:
If you want a progressive resolution for your desktop use something with 288 lines. However that will involve having your monitor's vertical amplitude adjusted to get those lines fit the screen, which can make readjustment necessary when playing 224-line games. I find more convenient to use an interlaced resolution for the desktop. You can use Arcade_OSD to select the desired resolution for the desktop.
emphatic:
Thanks a lot for adding NANAO MS9 support!  :cheers:
Navigation
[0] Message Index
[*] Previous page
Go to full version
