Main > Software Forum
Really *WEIRD* MAMEWAH problem
<< < (3/3)
liquid8:
--- Quote from: jakejake28 on September 07, 2003, 12:52:05 am ---
--- Quote from: liquid8 on September 06, 2003, 12:00:16 am ---for Win2k:
run Regedit
Find HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Change the shell value to your mamewah executable..
You can also do this for CURRENT_USER
i'll assume this is the same for WinXp, riht? ???
yes, XP is the same...
LiQuiD8
Xochi:
It sounds like the focus issue is probably what I'm seeing. I actually use a TweakUI setting to give focus to whatever the mouse is sitting on top of (this is like most UNIX GUIs which I actually use more frequently than Windows @ work). I'll try messing with that too, maybe it somehow is keeping MW from getting keyboard focus at startup.
jelwell:
Did anyone ever figure out the problem here? My friend actually has the same exact problem. He's using MAMEWAH 1.61.
I tried clicking on MAMEWAH, I tried using the task manager to switch focus. I tried resetting my mamewah.ini and re-downloaded mamewah 1.61. MAMEWAH definitely had focus, but just wasn't responding to any of my keyboards or ipac (I tried a ps/2 and usb keyboard).
I did some testing but couldn't get it narrowed down exactly.
He had MAMEWAH set to boot as the Windows Shell. That didn't work.
I set windows to boot up and put MAMEWAH in the Startup menu. Same problem.
I set windows to boot up and then manually launched MAMEWAH. Still didn't work.
It seemed that the first time I ran MAMEWAH, on my friend's machine, the keyboard was always locked. If I force kill MAMEWAH and then run it again it seemed to respond to keyboard/ipac input.
So... I wrote a batch file that looked (somewhat like this):
--- Code: ---WAIT 10 seconds
start c:\mamewah\mamewah.exe
WAIT 10 seconds
taskkill \IM mamewah.exe
mamewah.exe
--- End code ---
Even this didn't seem to work. The script itself runs flawlessly, but MAMEWAH still didn't receive key inputs. :( At this point I wasn't sure what to do - so I switched to Mala. ;) I swear that's not a threat. ;) I still use MAMEWAH at home.
Anyone figure this out? The only odd thing in the mamewah.log is  a line that says decimal figure found "." - or something like that.
Joseph Elwell.
Navigation
[0] Message Index
[*] Previous page
Go to full version
