Main > Main Forum
The cutest mouse "hack" you ever did see
<< < (2/2)
BadMouth:
--- Quote from: lilshawn on July 06, 2011, 12:24:09 pm ---i would think an optical mouse would work as well.
I experimented with an optical mouse on the backside of the steering wheel hub and it seemed to work fine.
(only played for a couple minutes)
Never thought of it working on two axis!
Someone could build a cheap flight yoke out of pvc or use one of those wii steering wheels that they sell at dollar tree for $1.
migraineman:
How about the Trojan Attack Mouse?
http://pentest.snosoft.com/2011/06/24/netragards-hacker-interface-device-hid/
An elegant attack vector, definitely a hack, and "cute" for certain definitions of the term.  You can't trust nuthin' anymore.  If your new USB mouse mounts as a mouse, a keyboard, and a mass-storage device, you should be concerned.
Thenasty:
the old MS-Mouse that had used POT inside instead of the standard WHEEL/Optical type mouse would probably work very good.
lilshawn:
Pot?
 Must have been designed in the 60's... Man.
Generic Eric:
--- Quote from: Thenasty on July 07, 2011, 11:42:58 am ---the old MS-Mouse that had used POT inside instead of the standard WHEEL/Optical type mouse would probably work very good.
I'll keep an eye out, I'll have to get another mouse.  The mice I have already have purpose and can't be sacrificed.
There are some cool designs out there.  Lew has a good design.
  I found another well done design used by someone into flight simulators
http://buggies.builtforfun.co.uk/Sim/FFB-yoke-1.php
Navigation
[0] Message Index
[*] Previous page
Go to full version
