Software Support > GroovyMAME
Pixel doubling on 31khz monitors with custom drivers?
Calamity:
I'm afraid that's all we can do about it, don't know if your monitor has any potenciometers on its chasis to correct geometry, anyway I woudn't even try. To be honest my Hantarex has similar or even worse convergence problems and I actually don't care.
If 31 KHz modes look better then you can try a pixel doubling set up as the one explained but I think it's not even worth in your case, I'l prefer to have the true low res modes even if somewhat squashed up.
lettuce:
Ah ok. Thanks for giving suggestions anyway :applaud:
jimmy2x2x:
I am almost ready to try this type of setup, I have a 4890 (at long last!) in the post due to arrive in a couple of days.
Just to clarify, do I need any special drivers or just the latest?
How would I add 2 custom resolutions, I want 1280x1024@50hz (Amiga) and 720x576@50hz (c64)
I currently get these 2 resolutions via powerstip (on an nVidia card)
Calamity:
Hi jimmy2x2x,
Just use the latest drivers. In order to add specific resolutions, edit the ReslList.txt file and add those using the same format:
--- Code: ---## Desktop ##
640 x 480 @ 30.000000 desktop
## Commodore ##
720 x 576 @ 50.000000 c64
1280 x1024 @ 50.000000 amiga
--- End code ---
Then run VMMaker to create them. Now, be aware that your monitor definition (monitor_specs) will need to have the proper ranges defined so that these video modes fall inside them.
jimmy2x2x:
Navigation
[0] Message Index
[*] Previous page
Go to full version
