Main > Main Forum
act labs light guns and k7400
<< < (2/2)
newmanfamilyvlogs:
I also swapped out the video cable for the one I used on the K7000, in case using the second set of h/v sync pins rather than the first made a difference; it didn't.
lilshawn:
does the 7400 display a regular white screen (not the calibration screen) properly? if not, i would suspect a B+ issue
if it does, i'm wondering if the calibration screen has a weird sync signal or refresh rate.... you could check by displaying it on a pc monitor. most monitors will tell you the frequency and resolution of the signal somewhere in the menu....
i'd compare a regular game screen (where the 7400 displays properly) and the calibration screen (where the 7400 lines on you) and see if they are different.
newmanfamilyvlogs:
Ill try an all white screen but that seems strange since I've not had any other issues like this so far.
As for the other suggestion, im not sure I have a monitor that displays that information to guest it with. That calibration screen is supposed to be identical to what's going in since you recalibrate at every resolution. Moreover on a multisync crt it doesn't change modes when you go into calibrate.
BobA:
Is this thread of any assistance?   Link from Act Labs
newmanfamilyvlogs:
I've looked over that several times. That's where I initially saw about not using Composite sync. Like I showed in earlier pictures, it WORKS on a K7000 just like the guy in that thread is using, using the same cable between the two monitors.
I saw a thread from back in 2003 where a guy claims he had his guns working on a K7400:
http://forum.arcadecontrols.com/index.php?topic=14005.0
Of course that's the only post that person ever made.
When I pull the trigger, the screen flashes what appears to be green, which is even more odd since the colors are correct any other time.
lilshawn:
I filled the screen with all white, and the display was unaffected.
Navigation
[0] Message Index
[*] Previous page
Go to full version
