Main > Main Forum
Golden Tee friendly control panels?
jimmy2x2x:
That looks like a workable solution - Could you measure the gap between trackball and glass for me please?
chopps:
TOK or EVEGames, how wide are your panels? this is the same layout i was going to use to avoid putting a huge box on the front of my cabinet.
EVEGames:
--- Quote from: chopps on August 18, 2010, 09:36:15 pm ---TOK or EVEGames, how wide are your panels? this is the same layout i was going to use to avoid putting a huge box on the front of my cabinet.
Chopps,
My panel is exactly 24" wide. Like you, I prefer a control panel which conforms to the width of the cab. At 24" wide, it was a very confortable and aestetically pleasing fit for a 21" CRT, and I find 2-player gameplay to be comfortable at that width as well. It's just the right spacing to be able to throw a quick elbow into your buddy's chest during a game of Track & Field, like on the 100 Meter Dash... On your marks... get set... ::elbow:: / ::starting gun:: and that's how you get a good head start.
TOK!
We're practically Control Panel twins! :cheers:
I like your design, man! And you took the extra step that I wish I had taken back in '04 when I built that first cab; the spinner. It's funny because you put yours exactly where I would have put mine.
-EVEGames
jimmy2x2x:
Mine is 21" wide
The distance from tip of trackball to glass is 7.5"
I might move the spinner over to where TOK has his, Ive stacked up some coins there and played as player 2 on the stick - seems like a great location, doesnt interfere with gameplay at all and I didnt knock over the coins!
This is just a rough panel made from scrap wood, Ill make a tidy final one when im 100% happy ;)
TOK:
--- Quote from: EVEGames on August 19, 2010, 10:30:42 am ---
Chopps,
TOK!
-EVEGames
My panel is 27.5" wide, 14.5" deep in the middle and the front of the trackball is 9.5" from the marquee.
I experimented with a lot of layouts and this one worked out the best for a do-it-all kind of solution. The bottom row of the player 1 controls is mouse buttons 1 through 3 (Happ trackball with 3 button harness). I originally had a separate set of buttons for the trackball, but wanted to clean the look up as much as possible.
Navigation
[0] Message Index
[*] Previous page
Go to full version
