Main > Main Forum
help with guncon
<< < (2/2)
tykenfitz:
--- Quote from: bkenobi on July 13, 2010, 12:42:52 am ---The drivers are calibrated for a specific resolution.  If you change resolutions, the gun won't move the mouse correctly on the screen which will result in funky behavior of the gun crosshair in MAME.
I thought that might be a problem, should I adjust my desktop resolution to the one that I play the game with the most?
Can I recalibrate it with each game?
Thanks man.
Derrick Renaud:
IIRC, WinGun does not work properly.  It can not create 2 independant mice.
Use Guncon2:
xoomer.alice.it/guncon2/
bkenobi:
Wingun does not create 2 mice if I remember correctly, but you can use it in MAME anyway.  You cannot use it in "mouse" mode though.  If you use "lightgun" mode, the position of the cursor is set each time a trigger is pressed.  I have not had any luck getting my Guncon 2's to work with MAME (non-custom compiled) for quite some time.  I have either custom compiled to remove the RAW input system or used MAME 0.117.
If you have a Guncon 2,  you need to use the Wingun driver as the other linked driver does not deal with the rolling x issue (or whatever it's called).
tykenfitz:
--- Quote from: bkenobi on July 14, 2010, 10:55:24 am ---Wingun does not create 2 mice if I remember correctly, but you can use it in MAME anyway.  You cannot use it in "mouse" mode though.  If you use "lightgun" mode, the position of the cursor is set each time a trigger is pressed.  I have not had any luck getting my Guncon 2's to work with MAME (non-custom compiled) for quite some time.  I have either custom compiled to remove the RAW input system or used MAME 0.117.
Thanks guys. I'l try using 117, but do I need to get the old roms to use it?  I'll try it later I'm replacing the sticking trigger microswitch in the guncon right now.  :angry:
bkenobi:
You can rebuild your set with CMP.  The other option is to check what gun games have been updated/added since 0.117.  I think I used to have a list, but since I've upgraded to a newer version, I probably don't have it any more.
Navigation
[0] Message Index
[*] Previous page
Go to full version
