Main > Main Forum
What is width of your Cabinet
r32:
Doh! :banghead:
Arcade Cabinet. I'm building and arcade cabinet. I don't have enough wood lying around for an arcade. :laugh:
Thanks for the feedback! I've got a lot of ideas going for my cabinet and based off what you guys said, I think I'll go 28.5" for width. Because that's the exact width opening (with .20" to spare) of my doors in the house. Now to figure out depth and other details. Hmm.
DashRendar:
The cabinet itself is one thing- the control panel can be super wide, as long as it's removable (which they usually are if they hang over).
Also remember that moving a cabinet through a doorway isn't always precise- having that two-tenths of an inch free space is ok if the cabinet goes through STRAIGHT, but if it's at even a slight angle, that free space quickly disappears and you could damage your door frame.
:dizzy:
Nation:
The inside dimensions of mine are 26 1/4" wide. I got a wells gardner arcade monitor + the bezel and so I based my width on the bezel. Didn't want to cut all four sides of the bezel and also thought the width looked good. I made sure it would fit through my door before building it though. My CP is 33" wide however like another poster mentioned it is removable and so it can be as wide as you need. It was pretty tight getting it through the door but it worked.
RobbyMac:
Wide enough for a 27" tv, narrow enoug to fit through a 29.5" doorway
At its widest point, it is 29"
The CP is latched (removeable) but it's 43" (4 player)
javeryh:
23-5/8"
The only playable cab on the first floor of my house at the moment is my DK+
Navigation
[0] Message Index
[*] Previous page
Go to full version
