It's has something to do with your monitors ability to display fine texture patters without having a shimmering effect.
Try it out with nokia monitor test.
http://www.softpedia.com/get/Multimedia/Video/Other-VIDEO-Tools/Nokia-Monitor-Test.shtmlOn most of the monitors I've seen you have to fiddle a bit with the moire setting to get it correct. Somewhere around 50 is usually right for me.
But my real question is whether or not you want to get rid of the moire effects at all. Does it tamper with the image accuracy to eliminate moire effects?
I used to crank up the sharpness on my monitors until I learned that all they were doing was applying a photoshop style filter over the image and not really adding anymore detail.
Is moire doing something similar? Sacrificing detail for a uniform image?
