Author Topic: Extra : in current time on layouts  (Read 2501 times)
bret540
  • Newbie
  • Last login:August 23, 2009, 08:54:53 pm
« on: August 23, 2009, 08:54:54 pm »
I'm creating my own custom layouts, and noticed when I use some text and define it using the pattern "~m_time", I always get an extra colon when I run MaLa.  For example, when the time is 6:51, the text that appears at run-time is 6:51:
I'm using a text field that only has that pattern.  I noticed that if the time takes up 2 digits for the hour, the extra colon is not printed.
Is this a known bug?  (Currently tested on WinXP Pro and Vista - running latest stable MaLa 1.5 - I attached a screenshot, see bottom right corner.)
mr_doles
  • Last login:November 13, 2014, 06:53:45 pm
  • nuff said
Re: Extra : in current time on layouts
« Reply #1 on: August 24, 2009, 11:50:54 am »
This will not answer why it is there but read here and here.
Loadman chimes in on the second one plus there is a work around from SGT, since you are creating it yourself it may help your out.
loadman
  • Moderator
    • MaLa
« Reply #2 on: April 05, 2010, 12:30:13 am »
This has now been fixed.
« Last Edit: April 05, 2010, 02:32:22 am by loadman »
