Author Topic: My cabinet build, or should I say update. LOTS of images.  (Read 2609 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: June 28, 2009, 11:24:52 pm »
Well, I finally finished my cabinet.  This originally was a cabinet that I got from fellow member quadmasta, which is itself a variation of LuSid's superb design.  The unit is solid, made of 5/8 MDF, and has a very nice component CRT in there.  It's also running a dandy ipac.  Here's what it looked like before:
It had coin mechs, switches, doors, and that cool MAME marquee.  However, this isn't how I was going to use it so I made a few "updates"
I posted awhile back about a dedicated mame version of linux and was able to mutate slax to do the job.  Also built and posted slax modules of SDLMame and Wahcade.  The unit boots into the menu system in about 15 seconds.  I needed to build the guts first, so I went to do it on the cheap.  The whole internals cost me $220, because I splurged on a video card that could output svideo, component, composite, and VGA.  I'm also running 2gb of ram and a gigantic 320gb drive.  The OS itself though boots off a CF drive for fast on/off.  Here's the hardware driving things:
quadmasta has a huge board running in the middle of the case for extra strength.  It also makes a great place to put the board.
The design is solid, but there were a few things I wanted to change.  First off, I wanted to fix the light and speaker layout.  Once I raised the monitor up 4 inches the original speaker layout wouldn't work, so I had to obscure the speakers up there with the light, which you can see here:
The CPL originally had 8 buttons for each player.  I'm only going to use 6.  I also modified the panel so it would hold the glass in place a little better, so I added a wood tongue on the top of the panel and trimmed the sides:
Now that it's all done Things look good.  Now to just add the finishing graphics.  Here's what the finished product looks like, with the plugs that cover the screws removed:
Thoughts folks?
Haterot
  • Last login:November 09, 2012, 09:27:41 am
Re: My cabinet build, or should I say update. LOTS of images.
« Reply #1 on: June 29, 2009, 02:02:04 pm »
Looks like you got some burn-in on the monitor, some guy with a camera stuck in there.  :lol Id also wood putty/sand/ those screw holes on the side.
I like your CP, clean and uncluttered. Very Minimalist.
Empire had the better ending. I mean, Luke gets his hand cut off, finds out Vader's his father, Han gets frozen and taken away by Boba Fett. It ends on such a down note. I mean, that's what life is, a series of down endings. All Jedi had was a bunch of Muppets
Gatsu
« Reply #2 on: June 29, 2009, 04:12:42 pm »
I think it looks good man. Are you planning on adding t-molding later on? Maybe blue? Just curious.
iscariot
« Reply #3 on: June 30, 2009, 08:15:22 am »
There's actually T molding on there already.  I wouldn't mind changing it up to blue though.  Does anyone know where to get 5/8 t-molding?
As far as filling in the holes, I'm not going to fill them in, I've got black covers that cover them nicely.  I'd like to be able to pop the monitor out in case I have to.  Quadmasta's monitor mounting was extremely solid
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #4 on: June 30, 2009, 09:51:42 am »
You can get 5/8" t-molding here:  http://www.t-molding.com/store/home.php?cat=2
Not as much selection as 3/4" but most of the basic colors are there.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: June 30, 2009, 11:33:55 am »
Yeah the corners and sides looked a little scuffed, so just get some filler and some snadpaper to tidy up those last few chips and holes then give it a fresh exterior lick of paint or maybe even laminate.
