Author Topic: Repair Toshiba p502sg Rear Projection Display  (Read 1845 times)
BlomSwe
  • Last login:June 15, 2009, 07:44:50 am
« on: June 08, 2009, 09:30:36 am »
Hello.
I've got some convergence trouble with a Toshiba p502sg in a of House of the Dead DX.
One day the convergence went away. I've changed the two large heatsinked convergence circuits.
The green is back to normal convergence, but the Reb + Blue are still way of . . .
grantspain
Re: Repair Toshiba p502sg Rear Projection Display
« Reply #1 on: June 08, 2009, 10:43:10 am »
it may be a faulty new ic or your resistors may be open circuit-i have had both happen
also check the pico fuses on the power supply board
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: June 08, 2009, 09:54:08 pm »
when purchasing stk series amp ic's , be careful . there are a number of FAKE STK's being sold by far too many distributors these days :soapbox:
the newer toshiba projos have a digital convergence module ( dcu/hyper module) that is chock full of surface mount 'lytics.  i.e. leaky/high esr , etc.....
to reduce callbacks , best to replace them all with STANDARD 105 degree 'lytics.
and currently have a 42h83 in shop for just that  ;)
qrz
BlomSwe
« Reply #3 on: June 10, 2009, 05:29:40 pm »
Thanks guys for the fast replies . .
Does any of you have the values/ratings for the following resistors:
(all are located on the convergence board!)
1) R744, R732, R739, R713, R725, R720 (all same = gold/gold/green/yellow?brown?)
2) RH05, RH14 (all same = gold/gold/Black/Yellow?brown?)
BlomSwe
« Reply #4 on: June 10, 2009, 06:05:19 pm »
I figured them out:
1 = 1,5 ohm 5%
2 = 1,0 ohm 5%
I hope that 2 W resitors will be enough?
