Author Topic: Do you guys calibrate your monitors/tvs?  (Read 2218 times)
giantgonzolez
  • Last login:July 17, 2004, 06:21:37 pm
« on: July 04, 2003, 11:59:26 am »
You can really improve the picture quality a lot of you properly calibrate your tv or monitor.
A professional ISF calibration will cost several hundred dollars.
However, there are much cheaper calibration alternatives too, but the results will be 1 step below a pro ISF calibration, but still a lot better than an uncalibrated monitor or tv.
Here's a free computer monitor calibration test that might probably also work for any VGA tv or VGA arcade monitor http://www.construnet.hu/nokia/Monitors/TEST/monitor_test.html
For calibrating your tv, there are several calibration DVDs available such as The Avia Guide to Home Theater, Video Essentials, and Sound & Vision Home Theater Tune-Up.
I have the Sound and Vision disc, and I also rented the Video Essentials dvd FREE with a free trial membership to netflix.
You really should calibrate your tv or monitor because it improves picture quality a lot.
Some people may find a calibrated monitor too dim at first, but that's because people have been so used to viewing uncalibrated tvs/monitors for so long.
Also, for best results when gaming, your gameroom should be darkened, and the only source of light should be a 6500k backlight placed behind the tv or monitor.
Generic Eric
Re:Do you guys calibrate your monitors/tvs?
« Reply #1 on: July 04, 2003, 06:00:07 pm »
I calibrated the TV in my living room.  Made a world of difference.  I shared my disc with several co workers who were happy with the results.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 29, 2003, 10:56:52 am »
If you use a commercial coin-operated video game monitor, use a Street Fighter 2 game board. It has an excellent monitor test pattern/color adjustment menu.
