Author Topic: Can't find 7/8 light blue tmolding, should I use 1/16 plexi on CP?  (Read 1278 times)
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
As the title suggests, I'm looking for light blue t-molding like this:
http://www.t-molding.com/store/product.php?productid=65&cat=9&page=1
But at 7/8 for the CP (since the plexi is usuallt 1/8), which I can't seem to find.
Has anyone ever used 1/16 plexi for the CP?  Will it crack easier when drilling holes?  Would a difference of 1/16 between them mean a difference in durability?
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
gatordad
  • Trade Count: (+11)
  • Last login:Yesterday at 10:47:42 am
Re: Can't find 7/8 light blue tmolding, should I use 1/16 plexi on CP?
« Reply #1 on: July 31, 2008, 11:41:58 am »
You could always route or sand the bottom edge of your cp, no one will ever know except you. ;D
« Reply #2 on: August 01, 2008, 08:22:04 am »
yeah - put a 1/8" 45 degree bevel on the bottom and use 3/4" t-molding with your 1/8" plexiglass.  It will actually look better if you are using 3/4" t-molding on the sides and stuff because everything will appear to be a uniform width.
Organic Jerk
    • OmeshPersaud.com
« Reply #3 on: August 01, 2008, 11:41:21 am »
I dunno... I'm kinda scared to cut into the wood like that because I fear I will frack it up.
The safer bet without cutting would be to use 1/16 plexiglass so that both the sides and the cp use 13/16 tmolding, but then 1/16 might be too thin to be of any use....
ARRGH.
Spaced Ace
  • Last login:November 03, 2010, 05:48:56 pm
  • "I'm surrounded by arcades!"
« Reply #4 on: August 01, 2008, 12:48:32 pm »
quarterarcade.com has 7/8 black.  Can't you go with the 5/8 blue instead?
I love your project, that cpo artwork is looking nice...
« Last Edit: August 01, 2008, 12:56:14 pm by Spaced Ace »
