Author Topic: tron spinner: anyone know how to remove the knob?  (Read 1851 times)
TheShanMan
    • My Arcade (updated 1/30/13)
« on: May 10, 2008, 04:09:30 pm »
I assumed the knob had an allen screw, but it seems not to be - it has a round hole and if I slide an allen wrench into it, it slides all the way in to the center of the knob. Anyone have a clue how to get it off?
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
Re: tron spinner: anyone know how to remove the knob?
« Reply #1 on: May 10, 2008, 04:21:07 pm »
Do not take the knob off!!!!  You will never get it back on without a lot of work.  It is a roll pin holding it in place.  To get the knob off there is a set screw under the control panel near the top of the shaft that the one the knob is attached to.   Look above the slotted wheel.  You will see 2 set screws on a shaft attached to the slotted wheel.  Then look further up and you will see 2 more set screws on a smaller shaft.  Lossen the top 2 and the knob will pull out with the shaft still attached.  If you must get the knob off the shaft you will need a small punch to knock the roll pin out.
Stan
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
TheShanMan
« Reply #2 on: May 10, 2008, 06:07:15 pm »
Thanks! Glad I asked. That was easy. Boy, they did their job making sure no one could steal parts off of the game - security screws on the joystick handle and not exposing the set screws on the spinner!
