Author Topic: MAME With Steering Wheel  (Read 2246 times)
Chazz
  • Last login:January 29, 2020, 01:14:53 pm
« on: May 26, 2003, 08:26:42 am »
Can someone tell me how I setup a steering wheel with MAME? Is there a FAQ or a good site with some info? I'm using a Wingman Formula GP, but I'm using the "2-axis, 4 Button Joystick" settings with XP. (According to Logitech this is the only way I could get it going). Also this is a Gameport device, not a USB if it makes any difference.
Thanks!!
~ ChaZz
Civilan
Re:MAME With Steering Wheel
« Reply #1 on: May 26, 2003, 09:33:09 am »
I'm interested in the same information too.
Over the weekend I purchased (minimal $) a Saitek R100 wheel w/ game port. I set it up (in Windows XP) by adding a custom controller as a 2 axis, 4 button, wheel. Once calibrated everything works well.
My problem is setting up the in game settings to make proper use of  the steering wheel, buttons, and pedals. I played around with the settings in SpyHunter and got the acceleration pedal to work but I still had shifting and machine gun mapped to the same button. I'm sure with more tweeking I'll manage to set things up properly. I tried another game but was unable to get moving in it because I couldn't shift. I forget the game but its from Atari, has crude 3D polygones, and a loop-d-loop in it.
What I think we need is a document that shows the input settings for each wheel game that makes the best use of the controls we have.
I tried Star Wars with the wheel and pedals for fun. It was a challenge to use the wheel to move the crosshair right and left in conjunction with the pedals for up and down. At least I know everything works.
Cheers,
Civilan
WaverBoy
  • Last login:May 27, 2003, 04:00:39 am
« Reply #2 on: May 27, 2003, 04:02:18 am »
I believe the arcade game you're thinking of is Hard Drivin'.  This has got to be one of the most difficult driving games I ever played.
Long live two-dimensional sprites!!!
Chazz
« Reply #3 on: May 27, 2003, 11:28:18 am »
Can I use any version of MAME with a wheel?  Where do I go to set up the controls?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: May 27, 2003, 08:25:01 pm »
Yes.  Enable joystick.
The quick (to explain) way is through pressing TAB key while in game.
Both these answers are addressed in the FAQ at http://mame.net and at http://www.mameworld.net/easyemu/ but the sites seem overloaded ATM.  It will clear up at some point.
A different and longer (to explain) way to set up controls is with ctrlr ini files.  Info on that is in docs\ctrlr.txt and http://www.mameworld.net/easyemu/mamecontrolini.htm  If you do it this way, it's best not to do the TAB way too.
Robin
Knowledge is Power
