Author Topic: mame32 pause, esc with ipac2?  (Read 1821 times)
antnida
  • Last login:February 17, 2009, 11:01:21 pm
« on: March 21, 2008, 02:03:28 am »
I have 2 buttons hooked up to switches #8 for p1 and p2 so that I can program them for Pause and ESC however, when I hit tap and try to change "P1 Button 8" to ESC it wouldn't work.  Did the same thing for "P2 Button 8" and change it to P for pause but it would not pause when i pressed the button.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: mame32 pause, esc with ipac2?
« Reply #1 on: March 21, 2008, 12:51:57 pm »
I think you're looking at it backwards if you're mapping in map, or confusing remapping mame vs remapping the ipac2. ??
The left side of the list of inputs is mame's internal input name, the the right side is what you press to do that.  So you want "UI Cancel" on the left to be mapped to whatever your button sends (joy1button8 or key'V' or whatever).
OTOH, if you're trying to change what the ipac sends, you have to use ipacs mapping application, and change p1b8 to send esc (so you don't need to remap mame).
Robin
Knowledge is Power
