Author Topic: WG 25k7193 Problem  (Read 3535 times)
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
WG 25k7193 Problem
« on: March 16, 2008, 01:43:34 pm »
Hey, I finally got a picture on my Arcade Monitor, but it seems to be mirroring itself. I am using nVidia's control panel and it seems to be working as far as I can tell.
Pictures:
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 25k7193 Problem
« Reply #1 on: March 16, 2008, 02:39:36 pm »
looks like a 15khz monitor being fed at 3x scan freq.
adjust nVidia settings accordingly
SirPeale
  • Green Mountain Man
« Reply #2 on: March 16, 2008, 06:13:59 pm »
Definitely some variety of sync issue.
Are you also using Soft 15KHz?
Xb0x3r
« Reply #3 on: March 16, 2008, 07:39:58 pm »
No right now I don't have Soft15KHz installed. Should I?
Xb0x3r
« Reply #4 on: March 16, 2008, 10:03:11 pm »
I installed it again and now there's no more mirroring  ;D
One more thing I have to fix is the picture being squished at the bottom, I'll update with more pictures tomorrow.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 16, 2008, 11:45:34 pm »
For the 'squishing' problem, adjust the 50/60 hz control as shown here:
http://jstookey.com/arcade/WG_25k7191/
Xb0x3r
« Reply #6 on: March 18, 2008, 08:37:41 pm »
I finally got around to taking a picture of the monitor. You may or may not notice it but you cant actually see the Taskbar or the Blue bar at the top that should be there. There is also a very noticeable flickering in the picture but it also could be because it is so close to a huge transformer, or the fact that my video cable is temporary right now (not making the BEST connection)
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 19, 2008, 12:04:35 am »
And you adjusted the 50/60 pot and the vert size? They interact.
Xb0x3r
« Reply #8 on: March 19, 2008, 07:33:29 am »
Yes I did adjust that 50-60hz pot, and it did make a huge difference but now I cant make V Size any smaller (I've maxed out the pot)
Ken Layton
  • Guru
  • Technician
« Reply #9 on: March 19, 2008, 11:29:53 am »
And this monitor has had a fesh capkit installed?
Xb0x3r
« Reply #10 on: March 19, 2008, 04:04:37 pm »
No it does not have a new cap kit installed, but I thought seeing that it's not THAT old it really didn't need it. Again on to me maxing out the V SIZE pot, anyway around this?  :dunno
Ken Layton
  • Guru
  • Technician
« Reply #11 on: March 19, 2008, 05:58:13 pm »
Capkit this monitor.
Xb0x3r
« Reply #12 on: March 22, 2008, 10:26:09 pm »
Can I get something set straight? On The Real Bob Roberts, he's got a cap kit for a K7000 (I'm assuming that would the the circuit board reference number). Is this the right cap kit I need for the 25K7193?
http://www.therealbobroberts.net/k7000.html
According to that chart, it looks like I need a K7000 cap kit.
Just trying to make sure.
Thanks,
Xb0x3r
Ken Layton
  • Guru
  • Technician
« Reply #13 on: March 23, 2008, 12:30:16 am »
Yes a 7193 is a k7000.
Xb0x3r
« Reply #14 on: March 24, 2008, 09:09:58 pm »
Well it turns out the resolution was just way too high for the monitor to display it properly so that when you moved your mouse, the screen scrolled with it. The monitor still does need a cap kit for good measure. But it has a really bad flickering. Bad enough to not be able to read anything small. Is there any way to make an attempt of fixing it? I'm going to make a temporary box lined with tin foil to insulate the thing.
Any ideas?
Xb0x3r
Xb0x3r
« Reply #15 on: March 27, 2008, 08:18:14 pm »
Bump  ::)
qrz
« Reply #16 on: March 27, 2008, 08:26:01 pm »
forget the foil and change the caps......
treat the cause , not the symptom  ;)
qrz
SirPeale
« Reply #17 on: March 27, 2008, 09:18:31 pm »
What resolution have you been running @?
Xb0x3r
« Reply #18 on: March 29, 2008, 09:43:39 pm »
Currently, it's running at 800x600...I cant really force it to go lower without losing my CRT PC Monitor.
Xb0x3r
SirPeale
« Reply #19 on: March 30, 2008, 10:58:36 am »
You can't do 640x480?
Xb0x3r
« Reply #20 on: March 30, 2008, 11:13:52 am »
I can try, but it seems when I force it down more, the PC Monitor just says "Frequency Over Range"
I haven't done it in a while but it did do that before I changed settings and stuff around...I'll try it tonight  ;)
SirPeale
« Reply #21 on: March 30, 2008, 11:53:50 am »
The idea is that you'll use just the arcade monitor, or PC CRT, but not both.  Are you still doing setup?
Xb0x3r
« Reply #22 on: March 31, 2008, 06:51:14 pm »
Yeah currently, the thing is sitting in my basement beside the PC Monitor (I have 2 arcade monitors, both the same model)
So I'll try to change it down right now and update in a few minutes!
Xb0x3r
« Reply #23 on: March 31, 2008, 07:00:36 pm »
Well I forced it down and the picture became worse! It still flickered a lot and also had scrolling lines across the screen  :censored:
