Author Topic: JVC-27WF35 Question..  (Read 1456 times)
illtww
  • Last login:July 27, 2013, 11:18:59 am
« on: February 20, 2008, 11:08:11 pm »
Guys..
My sis has this TV laying around and I remember it having a very good picture when she bought it in 2005.   It has component and I am thinking it will be a good fit for my cab.
Can anyone tell me what resolution this thing will let me run. 640x480?
I  can't find Anything on the resolution etc..
Thanks Guys..  :)
MonMotha
Re: JVC-27WF35 Question..
« Reply #1 on: February 20, 2008, 11:34:09 pm »
SDTVs are pretty much equivalent to standard resolution arcade monitors.  This means you can run ~240 visible lines progressive or ~480 visible lines interlaced on them.  Maximum horizontal resolution is determined by the input bandwidth of the set and tends to be around 720.  320/640 would give you square pixels, which you probabaly want.
Note that TVs are overscanned, so you won't see the whole picture anyway without adjusting things.
illtww
« Reply #2 on: February 20, 2008, 11:43:26 pm »
What are your feeling on ths tv?  Should look good.
has the 3d comb filter.
Can I run windows at 640x480 if I had to?
illtww
« Reply #3 on: February 20, 2008, 11:51:28 pm »
Also...
Does the virtual pinball table require higher resolutions?  Like 1024x768..
Also looking at this one:
Toshiba 27DF46... does hdtv...
« Last Edit: February 21, 2008, 12:11:23 am by illtww »
