Author Topic: ACT LABS lightgun (VGA/USB model) ... calibration offset by ~100 pixels  (Read 4211 times)
ARTIFACT
(on a CRT monitor, plugged via VGA > RGB via BNC leads adapter)
the title says it all
Am I not calibrating right? ... the instructions are VAGUE at best ("wave slowly back and forth...")
It seems to work with my monitor, I can shoot and it moves the cursor BUT it is off by 100 pixels both vertically (toward the top) and horizontally (toward the left)
Do you know if this is a sign that it won't work at all with my monitor/setup?
I currently have a gray smoked plexi in front of my monitor. I haven't tried without yet. Could this be the issue?
THANK YOU!
ARTIFACT
Re: ACT LABS lightgun (VGA/USB model) ... calibration offset by ~100 pixels
« Reply #1 on: September 21, 2007, 05:19:26 pm »
OK the act labs guys are GREAT
they replied to my email (which was essentially a copy/paste of the post above) and they already got back to me (within hours!) with a long and detailed list of advice on how to calibrate the guns correctly.
I will apply what they said tonight, and hopefully the gun will work well :)
thumbs up to the Act Labs guys.
weaklink
  • Last login:September 22, 2007, 11:42:28 pm
« Reply #2 on: September 22, 2007, 11:22:53 pm »
I hope you'll share the calibration procedure.  I've been really disappointed with the gun's performance.
ARTIFACT
« Reply #3 on: September 23, 2007, 12:59:41 am »
To summarize:
. in the dark (turning off room lights / 6 recessed flood lights) it works ok
. still have about ~30 pixels offset too high vertically (that's "ok"...)
. works beautifully in Model2 / House of Dead, etc
. CANNOT play in MAME ... set lightgun_device lightgun, etc... but the issue is that the gun button is not triggering the "Button 1" in MAME... Hitting the Happ pushbutton manually "shoots" where I last shot the gun.... WEIRD. MAME config???
I had fun in HOD though :)
mrudie
  • Last login:November 02, 2012, 12:54:43 am
    • LSEClan - Medal of Honor Spearhead
« Reply #4 on: October 21, 2007, 03:35:58 pm »
Any chance you can share everything that Act-Labs sent you for calibration help? (copy and paste?)
Mine is offset a little high and to the right.  The calibration instructions are pretty vague.
Thanks....
M37R01D
  • Last login:April 25, 2009, 06:23:25 pm
    • M37R01Dz M0Dz
« Reply #5 on: October 21, 2007, 07:43:03 pm »
same here, mine is a lil up and to the left,
i tried taking apart the gun and reposisioning the IR LED but that didnt do anything
please share the whole process :)
ARTIFACT
« Reply #6 on: October 22, 2007, 01:17:43 am »
I kind of got the problem solved by tweaking the screen's H and V alignments and stretch...
I also got all my gun games to keep the same resolution (switchres 0 in mame ini files) BUT for some reason games on the MODEL2 emu still have a BAD offset :( ... even though its all the same resolution and calibration works fine on mame games...
Grr
Also make sure you dont have a blarring light above your arcade... i did and it messed up aiming... unscrewed the 1  bulb and it helped.
lets share ideas
(oh btw no email came back from them after my post above... :(  ... i figure I may have become a bit too much of a demanding customer or something... I just want it to WORK)
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
« Reply #7 on: October 22, 2007, 12:10:44 pm »
Grr
lets share ideas
Hey, where can I get a list of gun games in Mame? I never even thought about setting them all to the same resolution, but it would fix the problems I'm having (I think)...
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #8 on: October 22, 2007, 02:37:09 pm »
Among other places, you should be able to get one on the MAWS site.  Use the deluxe search feature and narrow the search by selecting "lightgun" under the "control" category.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
ARTIFACT
« Reply #9 on: October 22, 2007, 10:57:10 pm »
I just made INI files for the few gun games I play a lot actually... :)
but the way I listed them is MALA. (the front end I use).. it has a LIST MAKER program which lets you generate these lists by genre, control, etc.
... and then there is MAWS's "deluxe search" too... just doesnt generate lists for you.
Xiaou2
  • Last login:Today at 03:37:36 pm
  • NOM NOM NOM
« Reply #10 on: October 23, 2007, 01:00:53 am »
I bought an Act Labs gun some time ago.   Utter crapola.
 The accuracy is so bad, that I permanently disconnected it in
frustration.
 I then got the  TOPGUN  guns, and they are a dream :)    Accuracy is
damn near perfection.   I highly recommend them.
 Act Labs also is known for hardware failures.   Check their forums
on pedal springs breaking in less than a few months use, and steering
wheel issues.  (If they even sell them anymore)
Banacek
« Reply #11 on: October 23, 2007, 01:17:31 am »
Sweet, thanks brother!
