Author Topic: 48-1 & 60-1 Jamma Board Swap  (Read 2259 times)
kansastj
  • Last login:August 22, 2008, 09:31:51 am
« on: August 28, 2007, 08:22:45 pm »
I'm new to arcade machines, but I have good carpentry
and electrical skills.  I just purchased a Sunset
Riders, Jamma machine w/ a 16" horizontally mounted
monitor.  Everything works but cabinet is worn and
rough.  After opening up the machine and inspecting
its internals, quite simple.
I really want a galaga machine, but due to popularity,
very expensive.  I noticed both the 48-1 & 60-1
boards have galaga.  I have found plans for the
original galaga cabinet on the net.
Questions?
1. Will the board simply plug into my Jamma harness
w/ no modifications?
2. Can simply keep all wiring hooked up the way it
currently is and transplant the monitor, wiring,
controls, ect., into a new (galage style cabinet) and
mount the monitor vertical w/ out any color issues?  I
know when you rotate a TV or Computer monitor, colors
change.
3. Can I set these boards to load galaga only on every
start up and avoid having to choose a game on every
start up / or every credit?
Thanks for your responce.
I know if would be simpler to buy a vertical monitor
Jamma cabinet, but I live in a rural area, could be a
long time looking for one.
Pros? Cons? Suggestions?
Sorry for nub question.
spacies
Re: 48-1 & 60-1 Jamma Board Swap
« Reply #1 on: August 28, 2007, 08:28:31 pm »
Welcome.
1: Yes. But be sure to add a Test and Service button to your loom.
2: Yes.
3: No. You can disable all the others so Galaga only shows and set it to Free Play.
Pros: 60 games without stuffing around. Plug and Play. VGA support so you could even ditch that old tube/monitor chassis and install an LCD or PC CRT.
Cons: Sound faults on a handful of games.
Good luck
spacies
« Reply #2 on: August 28, 2007, 08:31:53 pm »
Oh, and don't forget to add a trackball if you choose the 60-1.
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: August 28, 2007, 11:22:49 pm »
I've never tried to do it but I read somewhere the 60-in-1's will load directly in to a game if that is the only game set to show....
spacies
« Reply #4 on: August 29, 2007, 12:04:37 am »
You are probably right on that one Frizzle.
