Author Topic: Cabinet in white?  (Read 2486 times)
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
Cabinet in white?
« on: August 17, 2007, 07:28:41 pm »
I've noticed most cabs are done in black, either with some sort of melamine and then painted or plywood and then painted.  I've seen some rare cabs in white, and even one in pink.
But I don't think I've seen any cabs in white.  Is it just because it's not the true 'authentic' arcade cab, white gets dirty, or all of the above?
Just curious.
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: Cabinet in white?
« Reply #1 on: August 17, 2007, 07:33:39 pm »
Maybe for the same reason all computer cases now come standard as black instead of white  :dunno
My Galaxian is white, and will remain white.  I think Spacies made a white cocktail cab if you do a search.  I say go for it, just make sure you double check the "white after Labor Day" rule.
-csa
SavannahLion
« Reply #2 on: August 17, 2007, 07:36:59 pm »
To better hide the  :censored:?
« Reply #3 on: August 17, 2007, 07:59:39 pm »
spacies made some really cool white cocktails with silver t-molding.  http://forum.arcadecontrols.com/index.php?topic=60783.0
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: August 17, 2007, 10:53:10 pm »
Mine's white: (see pic at very bottom) http://forum.arcadecontrols.com/index.php?topic=21381.40
NO MORE!!
Avrus
  • Canada
« Reply #5 on: August 17, 2007, 11:00:25 pm »
How do you find the dust or dirt on the cab? How bad are the imperfections?
Green Giant
« Reply #6 on: August 18, 2007, 12:47:42 am »
I actually just picked up one of those little galaxian sized cabs that is white right now, but the laminate on it currently is really crappy.  It is made from particle board, so painting is out of the question.  I am thinking of relaminating it in white, but I really want to find some high gloss white, give it an i-arcade(apple) look.
There is really no reason you can't do it in white, but it will take more time as you will have to protect it some more.
As for authentic, doing it in white will have no effect.  If has the right shape, a good control panel, and good marquee/control panel artwork, white won't matter.
Toxic Arcade, my first build
spacies
« Reply #7 on: August 18, 2007, 01:21:22 am »
Cheers.
The white rocks!
Just make sure you build them from Meltecca/Melamime so you can clean it.
I visited a burger bar that has one of my white machines and it was still looking great after 5 months.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #8 on: August 18, 2007, 01:28:54 am »
I almost went with white for my cab but eventually went with red. Mine was originally a copy of the Sega convert-a-cabs like Frogger came in.
Sega made quite a few of their convert-a-cabs white. They're pretty much all white or wood-grain (like Frogger was).
Sega also made a bunch of white cabinets in the early 90's such as Virtua Fighter. There have been a couple projects converting these. It's surprising how good the chrome t-molding looks on these.
« Last Edit: August 18, 2007, 01:31:09 am by Crowquill »
northerngames
  • Trade Count: (+18)
« Reply #9 on: August 18, 2007, 09:21:29 am »
I have a viruta fighter cab that was deditcated and it looks great and whenever I get a dirty spot I use bleach lol
also instead of painting like I had thought I was going to after sanding it I noticed it looked like it was new again after the fine sand paper and I ended up leaving it like that instead of painting it.
RayB
  • There's my post
    • RayB.com
« Reply #10 on: August 18, 2007, 07:27:25 pm »
Well the machine gets little to no use and it's in a low traffic spot, so IT STILL LOOKS AS GOOD AS THE DAY I FINISHED IT!  :P   You'll notice though, the FRONT is black (textured vinyl adhesive). (Melamine for the sides)
I've visited an old arcade recently, and all the old white machines are all dirty, with shoe scuff marks all over the bottom fronts.
NO MORE!!
northerngames
« Reply #11 on: August 18, 2007, 07:40:57 pm »
that is a flaw with mine is the shoe marks on the bottom but I am going to use a 8 inch wide piece of grip tape from skateboards or similar to cover it and protect it again.
SodaPopinksi
  • Last login:November 09, 2011, 03:38:29 pm
  • Cold, Smokey, Rich Diet Caffeine Free Coke
    • John Keeler
« Reply #12 on: August 18, 2007, 07:48:52 pm »
I like the look of that Galaxian cab, I remember one of those from years ago at the beach in Misquamicut, RI in some little hot dog/cheese fry place :)
"Seimitsu LB-39's make me thirsty"- SodaPopinski
NoOne=NBA=
« Reply #13 on: August 18, 2007, 09:19:02 pm »
2 out of 5 of mine are white.
Those are both Nichibutsu cabinets.
koolmoecraig
    • My Intervention
« Reply #14 on: August 18, 2007, 10:53:59 pm »
I think cabinets in white look great.  It really makes the artwork pop.
I've seen an originally Namco Rally-X which was on white as well as a Screw Loose that a guy made out of a custom Q*bert cabinet.  Both look awesome.
I'd go with white on a custom cabinet for sure.
Avrus
  • Canada
« Reply #15 on: August 19, 2007, 02:52:10 pm »
Still torn on the color but I know a guy in a steel fabrication place so I'm going to put on aluminum diamond plate for the kick plate.  I think it will add a nice pop and prevent the cabinet base from being thrashed.
