The Neo-Geo MVS cabinets (2,4,and 6-slot) use a pinout very similar to the JAMMA pinouts. I've read before that running a MVS board in a JAMMA wired cabinet can overload the amp and burn it out. Would the same be true for the reverse (JAMMA in a MVS cab)?
I modified the wiring diagram from HardMVS to highlight the differences.
Although not indicated, in my MVS cab the ground from the left and right speakers connects to pin e or 27 (can't remember which). If connected to JAMMA, the MVS board is trying to output both left and right to the same speaker making a circuit. No wonder it overloads the amp.
Is there a big difference between wiring to the "speaker negative" pin and running it to a Ground pin on the harness? Audio is not my strong point.
I guess I could somehow rig up a DPDT switch to make it switchable if it is harmful.
The audio connections are the only ones that seem to be a problem:
E/5 - No connection
M - as long as the switch isn't pressed there's no connection
S/15 - No MVS cab even had coin slots 3-4, so no connection
d/26 - No connection
