July 29, 2010, 09:50:51 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
mamemarquees.com is now gameongrafix.com - new name, same great products and more! Click to see what's new!
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend controls.dat
Maximus Arcade Old Boards Old Archives
Unread posts | New Replies | Recent posts | Arcade | Rules | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Arcade monitor vs TV questions  (Read 1303 times)
manig
Trade Count: (0)
Jr. Member
Offline Offline
I want to Build My Own Arcade Controls!!
View Profile
« on: March 21, 2002, 02:34:29 PM »
Hi,
I currently have a MAME cab with a standard 19" arcade monitor. The cabinet looks like an Atari cab that was later upgraded to a Final Fight machine. I've wired the r,g,b,sync from the VGA directly into the monitor, as have many others here.
Everything works great, except that the monitor is too small!
So I have some questions:
1) Will a 25" TV fit into this (i.e. cabs with 19" monitors) arcade cabinet? As with most 19" monitor cabs, there is a large border around the display, and eyeballing it, I think at least a 25" display would fit.
2) If so, will it fit without having to take the tube out of the TV box?
3) How does the image quality differ between, a TV with s-video and an RGB arcade monitor?
4) Subjective question: is upgrading to a 25" monitor even worth the cost/trouble?
Logged
1UP
Token Junkie
Trade Count: (+4)
Full Member
Offline Offline
Yes, that is a joystick in my pocket.
View Profile WWW
« Reply #1 on: March 21, 2002, 07:44:37 PM »
A decent arcade monitor is often the same or cheaper than an SVHS TV.  Also, all TVs still have an interlace flicker that will be annoying at close range.  I'd recommend the monitor.
« Last Edit: December 31, 1969, 07:00:00 PM by 1026619200 » Logged
My other job...
My Halloween Animatronics
manig
Trade Count: (0)
Jr. Member
Offline Offline
View Profile
« Reply #2 on: March 22, 2002, 06:54:46 AM »
hi, thanks for the reply.
any pointers on where to obtain just an arcade monitor? are they easily available from arcade parts shops?
for me, ordering a brand new wells-gardner online is out of the question; shipping it to canada would simply cost too much, and i'd much prefer purchasing a used one.
thanks!
-Mani
Macros
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #3 on: March 22, 2002, 07:24:52 AM »
Where do you live in Canada? If you live in Ontario you can get a 25" monitor from starburstcoin.com. I bought a brand new 19" monitor from them for $225 can$. Or go to the auction and buy a crappy cabinet with a good working monitor then part out the cabinet and sell the bits and pieces on Ebay. Bring some tools to the auction so you can remove the monitor on the spot, that way it will be easier to transport the cabinet without concern over damaging the monitor.
Lilwolf
Trade Count: (+1)
Full Member
Offline Offline
View Profile
« Reply #4 on: March 22, 2002, 09:10:05 AM »
if you plan to go the windows route, I would strongly consider going SVid instead of an arcade monitor if you don't one one already.
http://www.xiaou2.homestead.com/turbo.html
this is a great show of the difference between a SVid tv and a SVGA.  I'm not sure how much better the arcade monitor is.  (anyone with both setup's and a digital camera willing to do some closeups?)
But the TV-out route will help the setup considerably and allow you to run windows applications/emulators.  There are only super old video cards that can handle the windows on an arcade monitor (g200 I think is the best right?)
I'm going arcade monitor next probably, but because I have a working 19".  If I didn't own it, I would definately go SVid
Agent Davis
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #5 on: March 22, 2002, 10:08:27 AM »
Manig,
I'm a good person to answer this since I did exactly what you asked.  I had an old Atari cab (missile command) and removed the 19" monitor and replaced it with a 25" TV.  I actually had to remove the TV from the housing to install it.  BUT, I believe my cab is a bit less wide than many 19" cabs.  My cab opening is 23.5."
The thing you have to do is measure, plain and simple.  There are thousands of cabs and they come in varying widths.  Also, some TV's housing is larger than others. So measure the inside width of your opening as well as height and then look at some 25" s-video tv's and measure them.
I really wish I could have kept it in the housing because it would have made mounting easier.  It would have also been a lot easier to move because I could just remove the TV and move them separately.  I'm moving out of here soon and moving a 600 lbs. cabinet is not fun.
AD
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.176 seconds with 19 queries.
