Author Topic: LED Wiz Mala plugin help.  (Read 5440 times)
Grinch
  • Last login:May 24, 2007, 10:54:06 am
« on: May 06, 2007, 06:25:47 am »
Hi, all.
Need some help setting up my LED Wiz. I've just spent a bit of time going through my favorate game list and setting up some cfg's for each rom that only light the buttons used in that game.
On the Mala gameslist I have all LED's set to ramp, but now when I scroll through the gameslist it loads up the game cfg for whatever game is selected.
Is there a way to stop the game cfg's loading so I can have my LED's ramp all the time whil browsing my game list?
loadman
  • Moderator
    • MaLa
Re: LED Wiz Mala plugin help.
« Reply #1 on: May 06, 2007, 08:21:22 am »
Hi, all.
G'day...
Would you please post your ledwiz.cfg file please
eg:
1,1,1,1,0,5,1,3,200,0,0,48\,1,1,1,1,1
P1_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,3,48,0
P1_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,2,48,0
P1_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,1,48,0
P1_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,6,48,0
P1_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,5,48,0
Grinch
« Reply #2 on: May 06, 2007, 08:32:24 am »
Sure no problem :)
1,1,1,1,0,5,1,3,200,1,0,C:\MALA\plugins\CFG's\,1,1,1,1,0
P1_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,1,48,2
P1_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,2,48,2
P1_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,3,48,2
P1_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,4,48,2
P1_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,5,48,2
P1_BUTTON6,1,SINGLE,0,0,0,0,0,0,0,6,48,2
P2_BUTTON1,1,SINGLE,0,0,0,0,0,0,0,11,48,2
P2_BUTTON2,1,SINGLE,0,0,0,0,0,0,0,12,48,2
P2_BUTTON3,1,SINGLE,0,0,0,0,0,0,0,13,48,2
P2_BUTTON4,1,SINGLE,0,0,0,0,0,0,0,14,48,2
P2_BUTTON5,1,SINGLE,0,0,0,0,0,0,0,15,48,2
P2_BUTTON6,1,SINGLE,0,0,0,0,0,0,0,16,48,2
« Last Edit: May 06, 2007, 08:39:57 am by Grinch »
loadman
  • Moderator
    • MaLa
« Reply #3 on: May 06, 2007, 08:36:10 pm »
OK The Config you sent means that the LEDS will always be ramping.
So you want all the LEDS to ramp while selecting games..
Do you mean
1) ALL LEDS RAMPED ...or
2) ALL LEDS FOR THE SELECTED GAME RAMPED
 ...  But when you launch a game you want the appropriate buttons lit (not ramped).. Is that right?
« Last Edit: May 07, 2007, 06:07:08 am by loadman »
Grinch
« Reply #4 on: May 07, 2007, 04:26:21 pm »
While in Mala and selecting the game I want to have all the LED's ramping. While in a game I only want the buttons that are used to be lit (no effects), and for a game that has no CFG file for all LED's to be on.
Is it possible?
loadman
  • Moderator
    • MaLa
« Reply #5 on: May 08, 2007, 01:15:20 am »
Is it possible?
Not with the current plug-in..
It should not be very hard to do that for you but you would have to be willing to beta test.
Grinch
« Reply #6 on: May 08, 2007, 02:12:50 am »
Aye, no problem with that :)
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #7 on: May 09, 2007, 08:39:42 am »
Is it possible?
LEDBlinky can do this.
Loadman - not trying to steal your thunder, just offering options.  :)
Robots will kill you.
Arcade Addiction
loadman
  • Moderator
    • MaLa
« Reply #8 on: May 09, 2007, 07:29:25 pm »
Is it possible?
KEWL   ;D
Saves me the trouble   ;)
loadman
  • Moderator
    • MaLa
« Reply #9 on: May 24, 2007, 06:57:06 am »
I decided to add this feature for V2.5.   ;)
* Ignore custom game configs while in game list
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« Reply #10 on: May 24, 2007, 05:44:02 pm »
Don't forget about adding the 49th intensity level (Instead of just 48)  ;D  :cheers:
If You Are Going To Meddle At Least Listen
loadman
  • Moderator
    • MaLa
« Reply #11 on: May 24, 2007, 07:36:02 pm »
Yep V 2.5 will have that as it uses Mike's Dll.    ;D
May still realease a OCX version too..   :dunno
Remind me, why do we need a level 49..?
headkaze
  • 0x2b|~0x2b?
« Reply #12 on: May 25, 2007, 07:09:28 am »
To quote Randy...
I would allow 49.  This was an error on my part when I made the control panel.  49 is ON, while 48 is still PWM.  The duty cycle is very high at 48, so there is no visible difference, but those who want to run relays or other similar devices (like the SlikStik color cycling joystick knobs) from the LED-Wiz need to use 49 to ensure proper operation.
loadman
  • Moderator
    • MaLa
« Reply #13 on: May 25, 2007, 07:14:42 am »
To quote Randy...
Ahhhhhh  Relay's don't like it  :P
« Last Edit: June 01, 2007, 08:39:47 pm by loadman »
