Author Topic: Mala and ROM names?  (Read 5599 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Mala and ROM names?
« on: January 16, 2007, 11:31:51 pm »
Can I have just the game name show up in Mala instead of the full ROM name?  I really don't need to know what version or revision it is or if it's a playchoise game.
« Last Edit: January 16, 2007, 11:35:16 pm by squirrellydw »
I b**ch. People listen!!
loadman
  • Moderator
    • MaLa
Re: Mala and ROM names?
« Reply #1 on: January 17, 2007, 01:58:14 am »
Yep use the malagamelist.exe
Some things such as items in brackets can be taken out in bulk automatically
squirrellydw
« Reply #2 on: May 20, 2007, 06:57:02 pm »
I was using this again today and I can't seem to get it to save the names in my favs list.
TOK
  • The Game Always Wins
« Reply #3 on: May 20, 2007, 08:39:08 pm »
You can remove the brackets and versions very easily... Right click, Options, Game Lists (upper tab), then select a game list, use the lower options tab (right above the list), Edit Game List, and you'll have text at the top that says Gamelist with all the naming options when you click it.
It sounds like a lot of steps, but it's actually very easy when you navigate through the dialog boxes.
squirrellydw
« Reply #4 on: May 20, 2007, 08:45:13 pm »
I can remove them but its not saving them for some reason or updating the list I have.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #5 on: May 20, 2007, 10:09:55 pm »
It may sound like a stupid question, but you are making sure to click "File" and "Save", right?
If so, make sure your emulator is setup properly, and I guess if that doesnt work make sure that no files are set to "read-only" in windows...
« Last Edit: May 20, 2007, 11:16:23 pm by OrganicJerk »
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
squirrellydw
« Reply #6 on: May 21, 2007, 09:27:42 am »
I bet its the read only thing, I will have to check that.
squirrellydw
« Reply #7 on: May 21, 2007, 09:37:28 pm »
was set to read only and umm saved to the wrong location, my bad
loadman
  • Moderator
    • MaLa
« Reply #8 on: May 21, 2007, 11:33:20 pm »
I'm sure MaLa will forgive you....  in time   :laugh2:
Thanks for your honesty..
Too many slam software first before they check to see if it is human error.   :D
« Last Edit: May 21, 2007, 11:36:04 pm by loadman »
squirrellydw
« Reply #9 on: May 22, 2007, 09:45:34 am »
it was MaLa's fault, it should have told me that it was saved in the wrong location, isn't that what the speech plug-in is for :laugh2:
« Last Edit: May 22, 2007, 02:25:40 pm by squirrellydw »
loadman
  • Moderator
    • MaLa
« Reply #10 on: May 22, 2007, 07:28:32 pm »
It would say ' Talk to the hand Joystick'  ;)
