Author Topic: Questions x 2: Gamepads and new pc I'm eyeing  (Read 1460 times)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« on: December 12, 2006, 01:06:10 pm »
Well, I put 4 USB ports on the back of my control panel for the Top Guns and potentially some gamepads. I have a 2-P setup right now, but if I could string a few gamepads for players 3-4 that would be niceness. Logical/possible and if so, what works well of the USB type?
Secondly, here's my current pc specs. Runs real well, but it's a surplus machine I was given by a friend and I'd like to give it back if I can upgrade sufficiently at a reasonable price. HD, video (Radeon 9600 Pro), sound card, usb hub will move to the new machine.
P4 2.2Ghz, 512MB ram, 250W PS
For about $285 I could move to a Pentium D 3.0Ghz, 512MB DDR2, 450W PS.  Worth the move? Thanks in advance gents... and rarely, ladies.
GT
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
Re: Questions x 2: Gamepads and new pc I'm eyeing
« Reply #1 on: December 12, 2006, 02:39:43 pm »
Possible.  That's how I set things up, here.  I use a 2-port Playstation to USB adapter because I already have the controllers (and dance pads.)  You'll probably have to customize the inputs of your games and emulators.  With MAMEplus, for example, I have to enable joystick input, but then I have to remap the buttons to player 3-4 instead of P1 an P2.  Dang, now that I think of it, I guess it is much easier to use joytokey to map the controllers to MAME P3 and P4 defaults, and leave joystick input off in the frontend/.ini
For $285, you may be better off with an entry level Core2Duo (e6300) system.
releasedtruth
  • Projected Nexus
« Reply #2 on: December 12, 2006, 02:58:57 pm »
Dual Shocks, why didn't I think of that? That's a great solution. I'd love to use something silly like my Saturn controllers, since I have 6 of them or so, but probably no USB adapters for those. 'scratches chin' Yes, that sounds real good.
When I priced out the low end Core 2s the processor alone was nearly double the price. 285 covers the case, cpu, power supply, ram, heatsink/fan, mboard.  I always get my barebones from mwave.com  Solid dealer.
GT
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« Reply #3 on: December 12, 2006, 06:25:53 pm »
DualShocks if you got them.  I use 2 Xbox 360 controllers (USB Wired versions).  You just download the drivers off of Microsoft.com
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
USB to dual shock
« Reply #4 on: December 13, 2006, 11:05:32 am »
Where does one go to pickup the usb to dual shock adapter?
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« Reply #5 on: December 13, 2006, 12:07:18 pm »
GT
You can purchase a Saturn USB kit From
http://www.retrousb.com/
Actually you can get pretty much any one you can think of from there.  I purchased the Genesis kit, and the adapter.  both work flawlessly  It took a little time soldering them together.  but i am very happy with the results.
releasedtruth
  • Projected Nexus
« Reply #6 on: December 13, 2006, 01:01:02 pm »
That's sweet! You can get USB dual shock adapters on ebay for cheap. One usb plug to 2 dual shocks. Not a bad way to go
GT
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
« Reply #7 on: December 13, 2006, 01:20:28 pm »
otherwise you can buy some dualshock style usb pad for 6$
I give up  fighting keyboard dislexia, I lost.
