Author Topic: Mala Background Inop  (Read 2502 times)
Dave Wave
  • Last login:January 13, 2019, 08:29:38 am
« on: November 18, 2006, 07:26:53 am »
Hi,
I am running Mala under win98 with an arcadevga card. I am having problems getting the background of my layout to show up in Mala. It shows up fine in the layout editor, but when I run Mala itself, the background is missing, but all the text boxes are there and everything works, just the backround is blank. I have checked the path, but no luck. The standard layout background (moonscape) shows up fine. Any ideas?
Thanks,
-Dave
loadman
  • Moderator
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
Re: Mala Background Inop
« Reply #1 on: November 18, 2006, 07:35:45 am »
Hi,
Thanks,
-Dave
Common question..  ;)
There are a few posts about it.
You can operate in two ways:
1) (default) 'use layout name for directory names' With this, the layout graphics need to be in a subfolder of mala with the 'same name' as the layout. This keep the mala directory a bit more organised
2) If you uncheck this option (see pic attached) the graphics just need to be in the mala folder.
Dave Wave
« Reply #2 on: November 18, 2006, 03:59:46 pm »
Loadman,
You know your stuff, that was the problem! Thanks so much for you help.
-Dave
Doctor Ugs
  • Last login:May 14, 2011, 02:56:58 pm
  • Arcade addict since 1980
« Reply #3 on: March 27, 2008, 07:46:38 am »
Holy cow thx Loadman, i been breaking my balls trying to get image to show up. :banghead:
Finally works, another problem solved using the all powerfull search in BYOAC forum
"My memory is so bad,
Alzheimer's would be an improvement!"
My Project Thread, 2 Mame Cabs.
loadman
  • Moderator
    • MaLa
« Reply #4 on: March 27, 2008, 08:04:15 am »
Cool, Don't forget the wiki too!
http://wiki.arcadecontrols.com/wiki/Mala_Layout#F.A.Q.
Trebeck
  • Last login:October 12, 2021, 11:01:21 am
  • "The Arcade" - Build #4
« Reply #5 on: March 27, 2008, 12:22:40 pm »
Hey loadman thanks a bunch for that.
I have a problem with the sounds in my layouts not working as well as the backgrounds.  I bet it's the same issue.  Ill post back if I get this resolved.
-Beck
Trebeck
« Reply #6 on: March 28, 2008, 11:08:08 am »
Yup, worked!
 :notworthy:
RoninEditor
  • Last login:April 14, 2009, 02:46:58 am
« Reply #7 on: March 28, 2008, 02:29:41 pm »
Thanks Loadman!!!  Effing A this was driving me INSANE!!!!
I've been looking everywhere, including the Wiki, but can't seem to find out how to get layouts to work when I have the "tree" checked.  When I used the default, all games thing, my layout (now) works perfectly but in tree mode, it goes right to the centered, generic Space Invaders one.
Hmm.
loadman
  • Moderator
    • MaLa
« Reply #8 on: March 28, 2008, 05:30:51 pm »
Hmm.
I don't use MaLa Tree but the info others have posted is here:
http://wiki.arcadecontrols.com/wiki/Mala_Tree
The only other thing is I think that you have to make sure the layout name is case sensitive. It needs to match to work i think. Maybee someone else can answer that
RoninEditor
« Reply #9 on: March 29, 2008, 01:18:34 am »
If I didn't have to, I wouldn't use a tree, but I'm hoping to get Daphne and pinball running, as well as gamelists for, say, "fighting games," "classics," etc.  Right now, when it starts (with the tree checked on), it defaults to the generic, centered-text, Space Invaders layout.  Apparently it's pulling from the "standard" layout file and, when the tree is checked, it greys out any other layout options I could have or make.  I have to figure out how to apply my layout to my game lists.
loadman
  • Moderator
    • MaLa
« Reply #10 on: March 29, 2008, 01:31:23 am »
I'm sure it's something simple like a naming issue
RoninEditor
« Reply #11 on: March 29, 2008, 02:26:54 am »
I'll definitely give that a shot!  You're definitely light years beyond what little I know.
