Author Topic: Optipac with 4 rotary devices?  (Read 1495 times)
ItzMR2u
  • Last login:January 30, 2017, 03:14:32 pm
  • This is my other car!
« on: March 20, 2003, 03:15:14 pm »
I have 2 optical joysticks and 1 trackball and 1 spinner.  If I hook up the trackball and the 2 joysticks to their respective connections on the Optipac that leaves me with the Player 2 Trackball connection for the spinner.  If I hook up the spinner there will I be able to use it for 1 player games even though it's connected at the player 2 spot?  Do I need to run a certain version of Mame to accomplish this set up with the Optipac?  Thanks for any help.
« Last Edit: March 20, 2003, 03:16:38 pm by ItzMR2u »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Optipac with 4 rotary devices?
« Reply #1 on: March 20, 2003, 03:59:14 pm »
Yes, windows see those as one.
Or you could wire the spinner to rotory 1 with the rotory joystick.
anoon
  • Last login:November 03, 2022, 09:24:53 pm
« Reply #2 on: March 20, 2003, 04:17:29 pm »
I was wondering the same thing. I have a trackball, two optical sticks, and two spinners. I had planned on hooking up the trackball, then wiring P1 stick and P1 spinner to X2, the P2 stick and P2 spinner to Y2.
I think I may need MAMEAnalog+. Does this sound like it will work?
SirPoonga
  • Puck'em Up
« Reply #3 on: March 20, 2003, 04:29:24 pm »
sounds right.
ItzMR2u
« Reply #4 on: March 20, 2003, 09:19:16 pm »
So the mameanalog+ will covert the vertical axis to a horizontal one so both the spinner and the optical joystick will work properly?
SirPoonga
  • Puck'em Up
« Reply #5 on: March 20, 2003, 09:40:12 pm »
analog mame allows you to split mouse axis.  also in windows98 it alows you have mroe than one mouse device.
